coilovers or stick with bilsteins
punk_sy
Post Wed Feb 17, 2010 7:44 pm
Hi every one :D . After abandoning my m50 project for over 6 months 8O Ive decided to finish it as I'm renting a workshop again at the end of the month.
I was going to use it as a track/fast road car but now i want to use it for manly drifting days after nearly getting banned in my e30 touring doing silly things around islands.
What I'm after is advice on my suspension at the moment the car has brand new h&r springs and nearly new b8 shocks. I was thinking about either selling this setup and getting some gaz coilovers (the street version) or use the shocks and make my own front and rear coilovers. The reason being i want height adjustment and more stiffness.
so what do you guys think should i just buy the coilovers?
caneswell
Post Wed Feb 17, 2010 8:50 pm
If you want height adjustment you don't have any choice surely??
But when will you actually adjust the height? Do you think you will make the most of it?
Post Wed Feb 17, 2010 9:12 pm
Why do you want height adjustment?
I would run stiffer springs with the B8's
handpaper
Post Thu Feb 18, 2010 6:41 pm
Dampers must match the springs, Jhonno, or it'll be stupidly bouncy.
You will probably need a much stiffer setup than H&R/Bilstein for drifting/track work. OE fitment springs can't be made stiff enough and low enough without ending up too short; coilovers can.
UweM3
Post Thu Feb 18, 2010 8:36 pm
handpaper wrote:Dampers must match the springs, Jhonno, or it'll be stupidly bouncy.
second that.
Sell the H&R (which ones exactly?) and B8's for a mainly road going car. Too soft for track IMHO
billgatese30
Post Thu Feb 18, 2010 9:11 pm
I have H&R's and a set of B8's and they're too soft for pure track work, great for the road though
12345kevin
Post Mon Feb 22, 2010 10:27 pm
Coilovers is the thing, i'll take the Rear B8's off your hands !
MillRat
Post Mon Feb 22, 2010 10:46 pm
KW V2's and everyone is happy (particularly you when your on track).
Cheers,
Michael.
Post Tue Feb 23, 2010 1:26 pm
second that.
He is after a 'streetable' from the sounds of it.. So therefore the B8's will be suited to such springs.
About the max you want to run on B8's is 400lbs on the front, which is a stiff road setup, quite a bit stiffer than the H&R's. Ideal for the brief he appears to have laid out
punk_sy
Post Wed Feb 24, 2010 10:52 pm
Hi guys thanks for the comments. I think I'm going for the coilovers as the car will be only used on the road some weekends. So not bothered about bumpy rides. Also then i can set their right height that ill need etc.
Uwe i think their the sport ones but can't remember i know their red tho. As soon as i get the unit sorted and get it on axle stands again they'll be for sale. Might also sell the LSD i bought of yourself! :?
cheers simon
UweM3
Post Thu Feb 25, 2010 8:32 am
punk_sy wrote:Hi guys thanks for the comments. I think I'm going for the coilovers as the car will be only used on the road some weekends. So not bothered about bumpy rides. Also then i can set their right height that ill need etc.
cheers simon
Simon, didn't we SWAP the diffs? Yours is still lying in my garage.
There is always the option for DIY coilovers.
Post Thu Feb 25, 2010 6:52 pm
Why the street setup from Gaz then? I would suspect the dampers like the B8's wouldn't be valved for stiff setups..
RPM
Post Sat Feb 27, 2010 9:03 am
Jhonno is spot on.
If your looking at the GAZ kits, the street kit really isn't valved for constant track use. The Golds obviously are.
On either kit we can supply any spring rates to suit application
UweM3
Post Sat Feb 27, 2010 10:04 am
I was wondering how long it takes...... winkeye
Post Sun Feb 28, 2010 7:51 pm
UweM3 wrote:I was wondering how long it takes...... winkeye
:lol: :)
punk_sy
Post Thu Mar 04, 2010 9:37 pm
OK thought about it and yes jhonno you are right :o: I'm going to go for the full track type after sorting out what car to use as Ive just bought 2 more e30s :mad: and what parts to sell or keep.
What spring rates would you guys suggest to start with if i was to use them on a touring with an m50 and fullcage? Stripped out obviously.
And does anyone know where i can get a fibreglass sunroof blanking panel or will i just make my own?
cheers simon
gareth
Post Fri Mar 05, 2010 12:19 am
i'm running 6" long 500lb/in front springs on my leda coilovers (M30 touring) unfortunately i don't know what the rears are. they're on the firm side but great on track :cool:
Post Fri Mar 05, 2010 1:23 pm
For track only, you are looking at 600lb front min, maybe 275lb rear min.. It's a little down to personal preference to be fair
