Post
Mon Feb 01, 2010 7:36 am
Dave, I currently have no ARB's on my track car, but have left the mounts intact to facilitate putting one or the other back if the need should arise (to tackle acute over or understeer problems should they arise).
However, before you decide that stiffer springs are an effective substitute for ARB's, first understand the difference between the two. Any one of the four springs on your car functions in such a way as to resist the "absolute" displacement of the attached wheel. That is to say, the force with which a spring resists the movement of the attached wheel is entirely a function of the absolute displacement of that wheel.
An ARB, on the other hand, opposes the "relative" (not absolute) displacement between two wheels. That is to say, an ARB exerts a force that is a function of the "difference" in displacement between two adjacent wheels. If both left and right wheels are raised equally high relative to the body/frame (compressing both springs) the springs will both oppose this displacement, but the ARB will exert no force on either wheel since the bar has no torsion applied to it when the left & right wheels are equally displaced. However when one wheel is raised higher than the other relative to the body/frame (as in the case of body-roll) the ARB will oppose this differential displacement with a force that acts on both wheels in an effort to bring both wheels back in line with each other.
So what does all this mean? What it means is that springs (by their very action) also work to oppose body roll since the force exerted by the spring on the raised wheel is greater than that, say, on the lower wheel (during roll). So stiffer springs can in effect be used to counter roll. The problem is that springs that are stiff enough to work effectively against roll substantially sacrifice ride comfort, and are thus generally reserved for lightweight track cars with a low COG. So long as your car is a track car only then stiffer springs in place of ARB's could work effectively, not to mention the fact the suspension components at each wheel now function independently of each other, which has numerous other advantages that I won’t go into here.
Apologies for the long boring answer. Hope I wasn’t teaching too many people to suck eggs.
