A solution called "THURMO" containing aluminium particals. will not clog water ways and cooling pipes but will repair cracked heads and leaking head gaskets.
bmwautorepair@hotmail.co.uk
they are the specialist I use, mega helpful , if you're in need I'd give them a try.
This is just a recommendation and not an advert.
M20 Head problems - The Cure
E30Adam
Rubbish.
There's no way of repairing a cracked head without having it welded and I wouldn't even trust a welded head.
2.8 Litre M20 powered - Essen Sie meinen Staub biatch
ditto as it would probably crack again next to the weld!E30Adam wrote:Rubbish.
tommo320i
If its gone under the camshaft this stuff works! no messing
Karan
LOL
prob shag the water pump too....
just have regular coolant changes and all will be fine....
gareth
naah, the best cure for a cracked 2.5 M20 is a M30!!!!
