E30 325i, from New Zealand
nzbimmer
Post Sat Feb 06, 2010 3:20 am
Both cars are now lowered, white one has Alpina Replicas (16") and have moved the 15" Basketweaves onto the Grey 320i.
//Rocky
Post Sat Feb 06, 2010 10:22 am
White one looks nice :cool:
/// KAMI
Post Sat Feb 06, 2010 11:45 am
//Rocky wrote:White one looks nice :cool:
THE ULTIMATE DRIVING MACHINE
god-father88
Post Sat Feb 06, 2010 3:19 pm
nice!! whats the white one lowered by?
Post Sat Feb 06, 2010 5:46 pm
looking good, ive never seen them 16" reps before
Post Sat Feb 06, 2010 9:25 pm
Alex wrote:looking good, ive never seen them 16" reps before
Look like a 16" version of the BK rep. Did BK ever do 16's?
Post Sat Feb 06, 2010 9:28 pm
thats what i thought, i think bk only do 17's and i think 18"s :)
The_Diddler
Love it up the more door !
Post Sat Feb 06, 2010 10:00 pm
Ahhhhhh, brace of moredoors :drool: :cool:
andrew320i
Post Sun Feb 07, 2010 1:00 am
Nice couple of E30's 8)
karimMSalama
Post Sun Feb 07, 2010 8:55 pm
that was some good cars
nzbimmer
Post Mon Feb 08, 2010 5:31 am
thanks for the comments guys.. i'm in New Zealand, theres a mag wheel shop here that sells them.. they are probably made in Taiwan or somewhere though.
karimMSalama
Post Mon Feb 08, 2010 6:43 pm
clean car
nzbimmer
Post Sat Apr 14, 2012 10:24 am
Well.. its been a few years since posting, I sold the above cars about 2 years ago, however I had the urge to get another E30, there's just something about them. (Have just sold my E39 528i).
This is my current E30, owned for 3 weeks now, it is a South African assembled car.
It seems that this model came stock with the Sport Leather Seats, Tech 1 Wheel, 14" Weaves and as you can see its a slush box model.
It seems to go well for an automatic, I suspect the motor is in better condition then the last 325i I owned.
Uploaded with ImageShack.us
TPS
Post Sat Apr 14, 2012 10:58 am
Thats Lovely, A/C, Big Tool Kit, South African built, what a nice car, is there alot of E30s in NZ?
nzbimmer
Post Sat Apr 14, 2012 11:06 am
TPS wrote:Thats Lovely, A/C, Big Tool Kit, South African built, what a nice car, is there alot of E30s in NZ?
Thanks, yeah there is still plenty around, but its getting hard to find a tidy one for a good price.
The 2dr Tech2 325i's in good condition with manual gearbox are getting expensive here, ie $12000, which is why I only have a 4dr automatic one, however for $500 I can source all the parts for a manual conversion.
TPS
Post Sat Apr 14, 2012 11:19 am
12000 Dollars thats about 6k?!, Big Money
nzbimmer
Post Wed Nov 07, 2012 6:21 am
Time for an update.
The car has now been converted to manual, using parts from a 2dr Tech 1 Coupe that was rusted out.
So gone is that horrible auto shifter and now it looks like it should.
I then decided it was time to give the car a power run on the local Dyno, to determine how many Horses had escaped over the years.
It made 138hp at the wheels, so its probably doing well for its age.
I ordered some boring parts, such as replacement engine mounts, distributor, rotor etc as the old ones were rather worn out.
I also gave the car a much needed valve adjustment and now it sounds like:
Its not perfect, but its improved.
A month ago or so I ordered a Miller Maf conversion, I installed this last weekend, however it causes the car to buck a little down low and some hesitation issues.
This was a WOT run with the MAF Conversion, it might seem ok on the video, but I could feel that it wasn't revving out as smoothly as it did standard, ie flat spots.
As a Temp thing I only have the POD filter on the MAF Sensor, however I have just ordered some parts to enable me to connect it up to the factory airbox, which seems bigger then most, it seems the south african E30 325's have a bigger one, I'll add a pic of it after.
I have ordered a new TPS Sensor, intake boot and some other parts, as I suspect I probably have vacuum leaks and a faulty TPS.
I have also ordered a B12 Pro-Kit Suspension (Joint effort between Eibach and Bilstein)
I went with this as I wanted the car to retain a level of Comfort while at the same time improve the handling.
They claim its tested at Nurburgring and fine tuned etc.
http://www.performance2.info/b12-pro-kit-en
nzbimmer
Post Wed Nov 07, 2012 6:33 am
Engine Bay, as you can see, useless Pod filter sucking in Hot Air.
However this is going back in next week.
Yeap, its ugly that air box, but its bigger then the ones they usually have from what I can tell.
nzbimmer
Post Fri Nov 09, 2012 10:18 pm
Airbox re-installed, with the help of some 2.75inch pipe, I could do with another hose clamp on it, but its actually ok.
genozide
Post Sat Nov 10, 2012 11:17 am
Like your passion on the E30.
razor4tuning
Post Mon Nov 12, 2012 1:33 am
very nice i like it
nzbimmer
Post Thu Nov 15, 2012 10:02 am
Thanks for the comments.
This arrived today, Billstein B12 Pro-Kit
With some new Front Shock mounts and upgraded ones for the rear.
http://www.bilstein.de/en-uk/products/s ... o-kit.html
nzbimmer
Post Sat Nov 24, 2012 2:34 am
4x4 Ride Height removed.
bmw335icoupe
Post Tue Nov 27, 2012 10:40 pm
the car looks really great on those eibach springs. What model is that and where did you buy them if I may know.
cheers.
nzbimmer
Post Wed Nov 28, 2012 8:02 am
bmw335icoupe wrote:the car looks really great on those eibach springs. What model is that and where did you buy them if I may know.
cheers.
Heya, it was this set from this website
http://www.turnermotorsport.com/p-22130 ... ckage.aspx
It was on special when I ordered it, I see its gone back to the normal price now.
nzbimmer
Post Sat Jan 12, 2013 7:13 am
Today I Washed, Clay Bar'd, Waxed the E30 using
http://www.supercheapauto.co.nz/online- ... escription
It was on Special for $50, which probably isn't that cheap, considering it only came with 1 Clay Bar, but it did the job.
I could have done a better job with the black bits and the wheels, but the main focus was on the paint.
Took about 3 Hours, which isn't that bad.
nzbimmer
Post Sat Nov 09, 2013 10:38 am
Its been a long time since I updated this.
Not much has happened, the car now has some Hartge 15" Wheels.
Sadly I have to use a proxy server to access E30zone now days and get the message " You have attempted to access this site with an invalid IP.
If you think this is a mistake you can contact the site webmaster at webmaster(at)e30zone(dot)net.
Be SURE to include the following information in any email!
User Agent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/30.0.1599.101 Safari/537.36
Remote Address: 111.69.155.116
Client IP: none
Forwarded For: none
I tried emailing the webmaster and it bounced back..
Anyway, here's a Picture of how it looks at the moment.
ImageUploaded with ImageShack.com
nickso
Post Sat Nov 09, 2013 12:37 pm
Your IP problem is common....happens to me all the time overseas.....highly irritating.
Nice E30 :)
'88 e30 328i M52 track bint.
