Since October I have been running the car on RON99 Unleaded rather than 95. I know the car is not able to adjust it's timing but I thought I see what the car runs like with the stuff.
Because of the higher octain the fuel will burn at a higher temp would this also cause the engine temp to be slightly higher or would it not have any effect on it? Also because it's burning at a higher temp am I right in thinking it will be burning cleaner and would reduce carbon build up ect?
The reason why I am asking is that the car is running really really well and the only thing I have noticed is the engine temp is running higher. I've checked the usual bits to make sure it's not the head gasket and the pipes are all ok. Finally I know people have claimed that they find they get a better return on the tank but I am still getting 230 miles per tank regardless of my driving and would I be doing any harm to the car using the 99 petrol?
Higher Octain higher Temp?
Morat
Higher octane fuel will not burn at a higher temperature.
http://en.wikipedia.org/wiki/Octane_rating
town325i
A piston threw the side of the block i would imagine that would be from something else and not running a higher octane fuel the only difference you will feel in a 325i e30 using this fuel is a lighter walletnomi wrote:i used to run vpower in my 325i. its lasted 6 weeks then it blew a piston through the block.
i always push the car.
but it felt quicker with vpower
i don't use vpower any more
- Brianmoooore
Running a higher octane fuel in an E30 than is required has NO effect at all on anything except your wallet.
If it does, then there is something seriously wrong with your car, as it must have been 'pinking' on the lower octane fuel.
It will be running 'better, at this time of year, as the inlet air is colder, and hence denser, than in summer, and as stated above, the hotter the engine the better, right up to the point it self destructs.
- JWaller360
Spot on, thats probably why it feels so much nippier than beforeBrianmoooore wrote: It will be running 'better, at this time of year, as the inlet air is colder, and hence denser, than in summer, and as stated above, the hotter the engine the better, right up to the point it self destructs.
