Yup cant find a real solution at the moment, the speedo works when it feel like it, tried some out of 318 and the speedo as expected is different and the rev guage reads high. So will I need a new set of clocks, or can the speedo be fixed? all bolts tight and connections look good on the cluster.
Regards Mark.
another speedo
swindy
"We aint here for a long time, we're here for a good time."
"Don't take life too seriously, you'll never get out alive."
Andy335Touring
It will probobly be the wiring and/or the connector by the speed sensor on the dif.
swindy
Sorry forgot to mention that when I hit hard itll start jumping around and sometimes work. Worked all the the way to work and then went indoors came out two min later and nothing dead!
Any help or still the diff wire? That seriously were the speddo pickup is? though it'd be in the gear box housing somewhere........
Mark
Mark
Andy335Touring
It could be a dodgy connection in your dash clocks but its usually around the speed sensor wiring/connector that goes wrong.
swindy
OK and that is on the rear diff? I shall have a look tomorrow.
Cheers mate Mark.
Cheers mate Mark.
The wire from the diff tends to break inside the plastic sheath about an inch from the plug. Pull the individual wires gently, and if one stretches, you've found the problem (or just made another one).
Post facelift 318 cluster is the same as a 325 one. The vehicle specific information is contained in the coding chip, which is housed in the little white pull out plug on the lower right front edge of the cluster.
Keep the coding plug with the car.
swindy
Thankyou, I will give that a try tomorrow, let you know. Cheers buddies.
Mark.
Mark.
