check the afm pipe is tightly done up at both ends, as are the little pipes that go into the icv, the throtle cable may not be tight so a delay in responce is noticed, also a dirty filter, leading to air starvation can cause it to suddenly choke. heavy scoring or carbonisation on the afm track may give wrong / confused intructions, or even a dirty TB may add to the delay.
im currently suffering from this aswell, so im gettin a 325i tb and slappin that on there, .. so even if it chokes im just gonna flood the bitch till she screams
