Fitting Adjustable Strut tops
agent006
Post Thu Jan 28, 2010 5:42 pm
Lots of talk here recently of the benefits of asjustable top mounts.
Question is, how easy are they to fit?
Theo
Post Thu Jan 28, 2010 6:57 pm
Same proceedure as fitting standard top mounts. You need to remove the front leg, take off the old top mount and replace with an adjustable type.
RPM
Post Thu Jan 28, 2010 11:01 pm
Very simple (as above), only a benefit if you use them as intended, ie to adjust the setup :)
http://www.raceperformancemodified.com/ ... mounts.asp
agent006
Post Thu Jan 28, 2010 11:20 pm
"Remove the front leg" sounds quite involved. Do I need spring compressors?
Theo
Post Thu Jan 28, 2010 11:24 pm
You should use them, but I don't bother. I just use a buzz gun on the top nut and the spring pops off with minimal fuss.
agent006
Post Thu Jan 28, 2010 11:27 pm
Cool. Any idea how long it would take a competent (i.e. someone i was paying to do it) mechanic?
Theo
Post Thu Jan 28, 2010 11:33 pm
I never pay people to do work on my cars so not really sure. It's do-able in an hour, certainly wouldn't take longer than 2.
agent006
Post Thu Jan 28, 2010 11:38 pm
Brill, thanks. Looks like I'll get it done for me. If it was a fiddly 3 or 4 hour job it'd be worth having a go at it myself.
Conan
Post Fri Jan 29, 2010 12:53 am
once there fitted how easy are they to adjust?
'91 Sterling Silver e30 320i SE
'96 Avus Blue e34 525i Sport
'92 Alpine White e30 318iS Touring
'86 Alpine White e28 M5 (008/187)
'02 Titan Silver e39 530d Sport Touring
'54 Cosmos Black e61 535d MSport Touring
'07 Sapphire Black e61 M5 Touring
RPM
Post Fri Jan 29, 2010 8:49 am
Conan wrote:once there fitted how easy are they to adjust?
Castor undo 3 13mm nuts and push back and fourth
Camber undo 4 hex bolts and move let to right
Minutes :)
Conan
Post Fri Jan 29, 2010 9:18 am
And are there clear 'notches' or markers to show what your doing to the camber and castor?
