Can anyone tell me which relay no' is for the fuel pump?
And is it located in the fuse box area?
Thx
Fuel pump relay - what number?
BadDave
Dunno about the earlier chrome bumpered versions but on the facelift ones it's behind the plastic panel on the bulkhead
On six pots it's under a plastic cover just in front of the left strut turret. There are sockets for three relays, but probably only two fitted - the missing one is for an oxygen (lambda) sensor heater. The two fitted are the main DME relay and the fuel pump relay. The main relay has a couple of large red wires going to it amongst others, and the fuel pump relay has a green/violet wire amongst others.
breitlingboy
Cheers Guys,
Mines got 6 relays fitted, all yellow.
Will have a look tomorrow to see which has the green/voilet wire to it.
Not the relays in the fusebox.
