Bolt that fits into towing eye hole
ijahn2000
Wed Jan 27, 2010 6:43 pm
Hi,
I have an E30 rally car and for that I need a front towing eye. I cannot use the standard screw in one, as this protrudes and hence the Fuzz wont be happy about that.
The alternative is to find a bolt that fits the towing eye hole and then to have a strap fitted to that. This way I continue to use the standard towing pick-up point on the front chassis rail, which is strong and I also no longer have something protruding past the front of the car.
To do that I need a bolt that fits into the standard towing eye bolt hole.
Anybody know where I could get one?
Alternatively any good ideas for other mounting arrangements are also welcome.
Ingo
BlueEyes_1
Wed Jan 27, 2010 6:58 pm
wind a nut onto the towing eye as far as it will go, grind off the "hoop/eye" then weld the end of the thread to the top of the nut??
just an idea :mad:
if you can see what i mean that is lol
To weld or not to weld thats the diff question?
ijahn2000
Wed Jan 27, 2010 7:48 pm
I know what you mean, and its a good idea.
I will need to check if the remaining thread still protrudes sufficiently to allow good engagement with the bolt hole
Keep the ideas coming!!!
bobbin1982
Wed Jan 27, 2010 7:56 pm
permantly weld a piece of threaded bar on to it?
Driving my digger!!!!
Chris
Wed Jan 27, 2010 8:45 pm
He would still need to know the thread of the towing eye.
I think its a wanky size coarse thread.
Good luck with the hunt.
Chris
Wed Jan 27, 2010 8:52 pm
The only thread you are likely to find that will fit into an E30 towing eye thread is the one on the end of an E30 towing eye! It's far from a standard thread.
Are you sure the protruding standard towing eye is illegal? From what I can remember of these things, it has a sufficient radius not to be classed as a sharp edge.
bobbin1982
Wed Jan 27, 2010 9:20 pm
Chris wrote:He would still need to know the thread of the towing eye.
Chris
Yeh had a dumb moment there sorry :roll:
Andy
Brian28
Thu Jan 28, 2010 5:45 am
Cut the standard hoop half way through with an angle gringer and bend it down, then weld the cut up to strengthen it again.
http://www.snappyracers.com/album/14110 ... _1592.html
For sale - E30 320i racer project - sold.
