Boot leaking....
Guest
Post Sat Feb 05, 2005 8:04 pm
My second E30 with a chuffing leaking boot. :x
Pool of water in the battery tray, no condensation on inside of the boot lid. Any idea if it's the light seal on that side? Where can I buy new seals for the lights? Cheers.
Simon
Post Sat Feb 05, 2005 8:06 pm
Could be the taillight seals, theyre still available from the dealer, could also be the boot seal itself, which is also still available from the dealer too.
E30Adam
Post Sat Feb 05, 2005 8:07 pm
Could also be the aerial or spoiler if you have one fitted.
Get inside the boot with a torch and get someone to run a hose over it.
2.8 Litre M20 powered - Essen Sie meinen Staub biatch
Guest
Post Sat Feb 05, 2005 8:16 pm
How does the boot seal attach and how do you get the old one off? Are they glued on and is it a right pain in the arse to do? Might order that and the light seals then if they're still available from the dealers. Anybody got any idea of the prices?
Simon
Post Sat Feb 05, 2005 8:21 pm
Taillights seals are about Ԛ£10, and the boot seal is about Ԛ£30, they both pull off, and the new seal is a really tight push on fit, the newer seals are an improved design too.
Post Sat Feb 05, 2005 8:54 pm
Take out right hand side boot liner (pull hard, it won't break), and carefully inspect the wheel arch for rust bubbles.
Right handwheel arch is very prone to rust because of the half liner, which acts as a dirt trap, and all the little brackets under there which are not coated in underseal.
popupstands
Post Sat Feb 05, 2005 9:00 pm
I have just ordered rear light seals & boot seal from dealer and total cost was Ԛ£33
al325i
Post Sat Feb 05, 2005 9:55 pm
Oh No 8O
Had the same problem with my 1989 sport, except I had it on both sides. Turned out both inner rear arches were rusted through, so check that out aswell. I hope it is only your boot seals, only wished it was with mine, as I have been quoted by 4 different bodyshops between Ԛ£500-Ԛ£1000 depending on how much fibreglass is done against welding in new metal :(
Good luck.
Alistair
Guest
Post Sat Feb 05, 2005 11:28 pm
Yikes, sorry to hear that. I certainly hope that isn't my problem! Will have a look tomorrow, it's been pissing it down all day today.
Post Sat Feb 05, 2005 11:40 pm
It's no big deal to MIG weld a couple of small steel plates into the rear wheel arches, (although beware of petrol vapours). It's not like you have to produce an invisible repair.
Dom
Post Sun Feb 06, 2005 2:46 am
I've got a leak, although it's where the lip on the boot where the seal goes has rusted through. doh! have to fix that...
al325i
Post Mon Feb 07, 2005 9:37 pm
Brian I only wish it was a couple of plates :( The right hand side is that bad that the petrol tank has got to come out 8O
As I said 4 different body shops have given me quotes and I have felt/seen some of the damage myself, my fist can go right through from the wheel arch into the boot :eek:
I only wish it was a couple of plates.................. :)
AL
ps Brian keep up the info on the central locking, its invaluble :)
Post Mon Feb 07, 2005 11:19 pm
Never had to buy one, so I might be talking rubbish, but I think the whole inner wings are available as replacement panels.
dc
Post Tue Feb 08, 2005 8:19 pm
my 318is boot was damp so i replaced said seals.still leaked.found a small hole in the water run off channel surrounding the boot lid.it was below the rear window on the lhs where the boot hinge was spot welded 2 the rear scuttle
