As above .
If yes are they a straight eplacement and are they quieter or do they tick as well ?
Can m50 injectors be used as a replacement for m20 2.5 ones
E30Adam
They cause the car to overfuel, use the correct injectors unless you have mods so extreme that the stock item's can't flow enough fuel.
2.8 Litre M20 powered - Essen Sie meinen Staub biatch
Ant
- Retired Team Member
Like mine and fozzys 42 lb/hr jobbies
thats 600cc/min, stock are 149
tried the e36 jobbies, cant say they made much diff in terms of noise dude, best bet is a spare set of the correct units and get them cleaned and flowed, @ least you'll be playing with a full deck for sure then
Email FTW
hogweed
How do you stop the higher-flow injectors overfuelling? Turn the fuel pressure down? In which case, how do you benefit form the extra flow... re-map?
E30 custom active sub for sale - PM for details
