M30 conversion wiring problems
ShineOn
Post Thu Jan 21, 2010 6:59 pm
Right, I'm tantilisingly close to the M30 being alive in my Touring, but there are some electrical issues.
I've a couple of very good friends helping me because I understand none of this, but does anyone on here have some pictures of their wiring in a converted car? In particular, the starter motor, the battery/relays please.
Or, is there anyone in the Redhill, Croydon, Godstone, Reading, Bracknell, wherever! that wouldn't mind us taking a look at how your car is wired up.
My engine came to a friend as needing a head gasket, which he did, but we've not seen it running so are not sure what problems we may of inherited. We can get it to turn over, but there is no fuel pump or spark, my alarm guy reckons the immobiliser isn't the problem (but we're not sure), and taking a look at another car would be a massive help. This has absolutely not been plug and play like I was expecting and I'm about to tear what little hair I've got left, out.
Post Thu Jan 21, 2010 7:06 pm
does your car have an OBC? a 13 button one
Ziggy
Post Thu Jan 21, 2010 7:24 pm
If you want to come over to Winchester, you're more than welcome...
You've read the sticky at the top of the section I trust?
Post Thu Jan 21, 2010 7:34 pm
The wiring issue sounds like either what Simon said or immobiliser.
The three wires you change round for this conversion is for the blower motor,elec windows and the starter motor.
If all those are working, it defo sounds like one of the 2 above.
ShineOn
Post Thu Jan 21, 2010 7:43 pm
Simon, yes I do have the 13 button OBC in the roof.
I've read the sticky guid at the top until I can say it in my sleep, but none of these issues are mentioned. We've made the wiring adjustments mentioned, but to be fair they do say they shouldn't affect the running of the engine. The blower is working, windows are working, so I think all is good in the hood with those.
Ziggy, thanks for your kind offer. I'll see how the sparky gets on taking the alarm out, if no luck I'll be in touch mate!
powelly
Post Thu Jan 21, 2010 9:03 pm
ShineOn wrote:Simon, yes I do have the 13 button OBC in the roof.
In the roof??? You sure thats not the check control, OBC should be in the centre console, it's my bet that Si is refering to the immobiliser code function on the OBC.
Image Le Mans Classic 2006
Post Thu Jan 21, 2010 9:04 pm
Well the obc on is easy, unplug it and see if it fires.
If it doesn't then its the immobiliser
ShineOn
Post Fri Jan 22, 2010 10:00 am
Sorry, my mistake, I was thinking of the check panel. Tired and arsey last night! No OBC fitted to this car at all.
Post Fri Jan 22, 2010 11:14 am
Thenits got to be the immobiliers or could be the DME relay
ShineOn
Post Fri Jan 22, 2010 3:10 pm
What is the DME relay, and how can I find/identify it? Is this part of the M30 loom, or the E30 side?
Appreciating your help by the way!
zaust
Zone day release
Post Fri Jan 22, 2010 3:16 pm
Near where the positive loops go on to the live terminal of the battery, there should be 2 relay's, one orange (fuel) and the other light blue (dme)
I trust you have a thick wire going from the + on the batt to the starter, And that you have earthed the engine to the chassis !!..
M30 Tech 1 Touring on gas.
ShineOn
Post Fri Jan 22, 2010 3:28 pm
Earth from block to chassis and live to starter are done, yes, with new wire and shiny connectors. But I don't recall a light blue relay. There was a White one with some thick gauge wire running from it into the loom, and an orange relay with regular thin gauge wire.
zaust
Zone day release
Post Fri Jan 22, 2010 4:29 pm
Some are white insted of blue, Same same. This is the dme relay, If this is faulty you will crank but not start.
First check the power at the starter motor. This can include putting a live probe direct onto the cranking terminal to see if it spins over.
Right then. Remove the steering cowling and expose the coulm and wires. The thickish black/yellow wire is your cranking wire. Trace it back to the connector box and check that's all plugged in and not loose, If you see it(black/yellow) has been cut anywhere, and start's trailing off with other wires connected to it, then this an after market imobilizer/alarm. Cut them out and re-join the Black yellow. You also need to check that this wire is going live when you turn the key to the last position.
ShineOn
Post Fri Jan 22, 2010 5:18 pm
Ok, that makes sense, thank you. I believe the White one is working and can be heard clicking. I spoke to the alarm guy who fitted it and he mentioned a black and yellow wire is what he would have tapped into, so that's first thing to check when we get back to the car.
We rigged up a sprung starter/ ignition switch that operates the starter, so we know that works fine (starter is brand new) and the engine turns over cleanly.
zaust
Zone day release
Post Fri Jan 22, 2010 5:38 pm
It's all down to the black yellow split then. Enjoy the drive. I'm about to go out in mine for a blat winkeye
