si board batterys
spinner100
hi all does any one know where i can get a good price on a si board battrys as my instrument cluster is playing up and i have been told this is more or likely the problem.my local bmw dealer wants to charge me £185 for this part it just seems a little steep. any replies would be much appriciated........
- Brianmoooore
CPC/Farnell, RS components.
spinner100
thanks you must be getting bored of answering my questions............
- Brianmoooore
Depends whether you need Lithium or NiCd ones.
spinner100
Managed to get a complete board with batterys but now the speedo works but not the rev counter
I will look tomorrow. Are they typical AAs?Chris-W wrote:Open it up and have a look. They have it written on them.George wrote:How would I know?Brianmoooore wrote:Depends whether you need Lithium or NiCd ones.
Sold: 1986 E30 325i Cabriolet, Alpine White
spinner100
no they are funny little 3 v batterys in my opinion mate you would be better to get a new board as the batterys are soldered in and are covered with a rubber silocone so are very hard to get out. i got my board for 40 pound. i still have problems though...........
spinner100
what year is yours mine is 89 and has the stubbys.
Chris-W
- Contact:
Honestly not sure, sorry.George wrote:Is there a year where the change occurred?Chris-W wrote:Nickel Cadmium are the usual AA size, Lithium jobbies are 'stubby' to give them their technical name.
Chances (odds on) are that if they've failed you have the earlier type. All that I come across that have failed are the earlier type, earlier cars with still functioning clusters most usually have the replacement type later board (discernible by a storage jumper, no, not knitwear).
spinner100
its really easy to get your instrument cluster out and to remove the si board from it and check them.
So it is possible to 'upgrade' the earlier type to the later type?Chris-W wrote:Honestly not sure, sorry.George wrote:Is there a year where the change occurred?Chris-W wrote:Nickel Cadmium are the usual AA size, Lithium jobbies are 'stubby' to give them their technical name.
Chris-W
- Contact:
Later type, here I mean single red SI light boards, are a straight swap, yes. I.e. Nicad to Lithium. Hope that makes sense.George wrote:So it is possible to 'upgrade' the earlier type to the later type?Chris-W wrote:Honestly not sure, sorry.George wrote: Is there a year where the change occurred?
- Brianmoooore
The earlier boards had NiCd batteries, and the later version used lithium cells, BUT it's very unlikely that many E30s are still on the original NiCd batteries, and most will have been replaced at least once by BMW.
The replacements may have been lithium powered boards or rebuilt NiCd boards, depending on what was in stock at the time, so there is no way of telling what any particular E30 has in it without looking.
Most of the odd problems are caused by boards with the NiCd batteries, not by them losing charge, but by their habit of becoming short circuit when they fail, and 'loading' the power supply for the other instruments.
The main problem I have seen with clusters fitted with lithium batteries is a fairly trivial one of the tacho needle jumping up to several hundred revs when the engine is off, but, since the lithium batteries are not rechargeable, if a cluster with one of these boards is stored for a length of time (years), without the board being switched off, the batteries will permanently fail.
- Polanskygreg1985
it's really not that easy, in fact, its a pain in the ass. I gotta replace mine as well, but im not sure which ones to get, would these work? http://www.batteriesinaflash.com/bmz_ca ... 00x240.jpgspinner100 wrote:George wrote:Is there a year where the change occurred?Chris-W wrote:Nickel Cadmium are the usual AA size, Lithium jobbies are 'stubby' to give them their technical name.
- Brianmoooore
Like most jobs on an E30, if you find it difficult, you're doing something wrong!
What particular part do you find is "a pain in the ass"?
Which batteries you need will depend on what version of the board you have, but whichever they are, they will need to be the type with solder tags fitted.
