As the title says guys and girls. Whats the lowest I can go without fouling the arch's? The car has 18's at the mo but looking to go back to original 16's.
Picture below of the car
cheers
[img][img]http://i632.photobucket.com/albums/uu48 ... /bmw36.jpg[/img][/img]
E36 suspension
dapperdan8001
e30bmlover
- Ac Schnitzer prophet
i dont know what mines been lowered to... but i do know that the trailing arm bushes were replaced on thursday!! mines on 17's...
dapperdan8001
The drop on the front of yours looks pretty much how I want it to look.
/// KAMI
It loos about right i think.
THE ULTIMATE DRIVING MACHINE
FMH
I've got my e36 lowered on apex 35mm front/45mm rear. 18's. 225/40 on the front, 255/35 on the rear. Can't even get 1 passenger in the back, it bloody rubs hardcore.
35mm drop is what you want.
eko
- Old timer
I have my coupe pretty low on cheapo coilovers with chav spec 235/35/19 tyres and get no rubbing at all
FMH
i'm thinking my wishbone bushes have gone again, causing the wheels to point inwards on either side. when i do get down to changing them, i think i'l do a diy allignment as its too low to get it done professionally, should kill the rubbing.eko wrote:I have my coupe pretty low on cheapo coilovers with chav spec 235/35/19 tyres and get no rubbing at all
Kos
you can go very low if you pick the right off set and wheel size
in my compact i run 8x17's et and 205/40 tyres, wheel et is 15 which means they stick out a but, the front is lowered about 60 to 70mm with no arch mods at all, and i can get it down an other 10mm easily. the backs about 40mm lower with the same spec wheels and tyres. it required a light roll
the touring, whch was even lower, and had wider 17's and lower et , i flared the front a fair bit and rear arches a touch. i had 215/40's on the back and boot full of ICE
get on to the e36 coupe forum, there are plenty of people running big wheels with out any aggro.
if you want 16's you can go very low on stock wheels, BUT the tyres may catch on the rear inner arch, no the lip the actaul wheel housing.
oh and hers' small speed bump clearance
sorry for pic whoring
dapperdan8001
when your motor looks like that you can post as many pics as you want mate. Would ideally like sum 17 inch sunflower rims but do you think its best to change springs and shocks?
