recon half shaft is about £350 each from bmw! i bought a CV boot repair kit a few years ago for about 15 quid from the dealer i'm sure
The S in my diff is original, theres one on the top also
town325i
i did ask about a half shaft but i think i dropped to the floor before they finished telling me the price
The_Diddler
- Love it up the more door !
I've got my 2 refurbished, get them tomorrow, big thanks to DanThe for sorting that out......
£95 ish plus the VAT per side, was happy with that
Looking good Si. Theres a few bits I need to order for my diff today.
Drive shaft is £328 + VAT from the dealer + 20% surcharge if you dont give them some back!
- Homo Hair
I paid £15 the other week..town325i wrote:its a good job the cv boots are in good condition realy as when i asked about some a few years ago they where £90 each
Another day off work, another day in the garage!
Otherside getting there, halfshaft back in
Nice and clean ABS sensor, i cleaned the life out of the trigger rings on the halfshaft
Some nice Brembo standard rear discs, £40 odd the pair from GSF. BMW wanted £45 PER disc, jog on i said because they won't last twice aslong as these brembos.
One thing which annoys me on bmw's, well the new ones is how quickly they rust! So heres my attempt with some hightemp paint. I hope it works. I did 2 coats
All nice and dry ready to go on, and adjust setup me handbrake
Nice and fookin tight handbrake, 3 to 4 clicks and the wheel can't move is how we like it! Too many E30's with an erectional handbrake levers!
/\ Does this look right for how the wires around here go. To me it seems good but your memory only remembers how they run on a dirty car and it looks alot different under here!
Like a dick i forgot the diff oil temp guage for the vent guage, so heres me threading the wire through the bmw grommet to kept it factory looking
All in and looking ok, that black clip holding the speedo and temp wire up, f**king pound £1.20 each from BMW!
Got have it though
Looking like a rear end
New rubber grommets for the fuel tank, the washers are re used, they are nearly £2 new each so i went tight for some reason, but i bought new bolts
Tank in! I didn't bother connecting much up, that can be 2moro. I was quite keen to get her off the axle stands to see how low it might sink..................
Bit low innit, i like it. Defo cooking on gas at the moment
So just the calipers/brake lines left, the filler neck and fuel breather system and the rear anti roll bar with drop links. So very nearly finished in this area!
Looking good si, Where do you buy the underseal from, is it the same stuff as they left the factory with? should it be black?
Bob_S
going well there Si! coming together nicely now
Bollocks to this 24v scrap!
town325i
will this car be ready for santa pod this year or is that asking a bit to much?
No no, i'd like it done this year if i can. For santa pod or Gaydon would be nice but we'll see how it goes.
Alex i've repainted the underside Vauhall Gazelle beige
Its a bit too yellow for the factory look tbh its more like Peugeout antellope beige and whiter lol. I thought it would look better than bits of old, the grey the bodyshop did and the black bits i've added also tidying up some flaky parts.
I've got the part number for the BMW stuff, but you need a shultz gun and a compressor to use it Alex. Its f**king great stuff though. Its not the stuff the factory applied new but close, it only comes in black or grey but you can paint on it as you can see lol
GC318
looks like it's coming along nicely Si, well done fella
goosiegander
- Zonegoose
Epic work!
I spent a good few hours of my last stint onboard my tug rereading this thread pretending to check weather patterns, its inspiring stuff.
How much longer do you think you need to finish it?
Santa pod? Alpina 2.7 build??????????????
Si, let me know this Sat's lottery numbers and we'll split the jackpot
Thanks!
I need more money, and time! Really now is the time to start re-building the engine to keep it flowing. Still plenty i can get on with here, which i shall do, seeing as this cold weather is keeping me off work for another week it seems
So this keeps me busy and out of trouble.
I'm aiming for an MOT on it this year, it will be the latter part of the year no doubt!
Alex underneath it was mostly beige, but the arches and other parts have over spray in black from the factory.
GC318
4 9 13 15 21 27 - good luck TrevorB7 wrote:Santa pod? Alpina 2.7 build??????????????
/// KAMI
good work mate keep it up
THE ULTIMATE DRIVING MACHINE
I've got an idea..... and you know what it is SimonSimon13 wrote:Thanks!
I need more money, and time! Really now is the time to start re-building the engine to keep it flowing. Still plenty i can get on with here, which i shall do, seeing as this cold weather is keeping me off work for another week it seemsSo this keeps me busy and out of trouble.
Strip it down again and paint it diamond black?
Well done Si
Well done Si
scott180gtb
WD 40 the screws and leave them overnight. I only managed to snap one screw. A little too small to use an east out!
Cars
2007 VW Caravelle 2.5 TDI 250 bhp 550 NM
1989 325i Sport Gone
2003 E46 320d Touring
1998 E36 M3 EVO Track Toy
1996 E36 328i Sport welder-up project
Thanks i've managed to sort it now, much to my relief
Tank plumbed in here both sides,
Comes up empty on the clocks now so must be working as the light is on also!!
These were in the bloody way! So i thought today they can actually be fitted so on they went shiney new splash guards
Gave in here a good clean up
Alpina long range tank, extra 30 litres so i can spend over £100 filling it up now
That breather pipe hanging down there comes in through the inner arch at the top through a big rubber grommet. I measured it today 30mm it needs to be. I shall be in tears doing that!
Shitty bit of carpet to hide it,needs a serious clean first
This has been bugging me for a while now, the repair panel from bmw didn't come with a threaded stud to fix these trims. I was going to Riv nut or drill it and nut and bolt it. But i'm thinking sod it now, as the pina tank holds it all nicely, plus they love to rust here and drilling or anything like that isn't going to help the matter.
What do we think not quite 100% but..........
GC318
The question Si, is what do YOU think. If your ok with it then fine but if you want it 100% and don't do it you may regret it.
Agreed, leave it loose so you can regularly check behind/waxoyl it. My Sport went badly there.
it was rusty there before so i'm going to leave it as its not now as it had a large section of inner inner arch welded in there! The pictures will be somewhere on here, pages 20-25 i think is bodywork
glenn
- Engine Transplant Services
wow, this car really is coming along nicely now.
give yourself a pat on the back, you deserve it.
Royalratch
New wheel liners are cool aren't they - make such a difference visually.
Agreed, Leave it. Hindsights great but a little m6 thread brazed in place before paint would have been a nice tough but hey ho. F*ck drilling it now. asking for aggro.
Simon, I ordered one of these last week and it came today, more like £15! Its 50p odd per metre, on the label it states 1 roll = x25Simon13 wrote:
I found this on RealOem whilst looking for clips, loom cloth tape for the engine bay etc. 53p for the roll, love it
Part No. 61 13 6 902 588 for all the resto homos out there
Rip off or what!
I also enquired about these, £40 outer and £35 inner, once VAT is added on your not far off £90 per shaftJhonno wrote:I paid £15 the other week..town325i wrote:its a good job the cv boots are in good condition realy as when i asked about some a few years ago they where £90 each
my dealer must of made a kind mistake! opps
gareth
fook that!
PVC tape for me then!
- Homo Hair
I don't have my receipt to hand, will dig it out and check.. I bought a z3m diff bush, cv boot, diff cover gasket and it came to £57....DanThe wrote:I also enquired about these, £40 outer and £35 inner, once VAT is added on your not far off £90 per shaftJhonno wrote:I paid £15 the other week..town325i wrote:its a good job the cv boots are in good condition realy as when i asked about some a few years ago they where £90 each
tomson
I replaced the 4 front cv boots on my iX about 6 months ago, it cost around £75 per shaft....
http://cgi.ebay.co.uk/Classic-car-vehic ... 58851d2200gareth wrote:fook that!PVC tape for me then!
