320i Cabby - All Back together Pg. 3
/// KAMI
Nice looking cab....
THE ULTIMATE DRIVING MACHINE
Found a small patch of rot in the floor under the rear heating duct
its been cut out and a patch has been made to be welded in
also there is a small soft spot around the rear set belts, poss an mot fail
Roof has been adjusted and so have windows as well as them being put back into the rails
, a tear in the roof has been patched up from the inside.
Paul seems to think the water is comming in from the seems where the material goes around the metal roof bars.
temp black tape
his mate is comming over to put patches on the other side of these
got all interior cleaned with wet vac and looks almost factory fresh, seat rails have been painted and seats have been partially rebuilt so there not wobbly anymore
even this has come up ok
looking a bit sorry
temp black tape
looking a bit sorry
Ollie_bwoii
Can't believe how good that interior has come up!
Going to look awesome when back in the car.
Looking good. Is this a car for summer?
all the time when its done
RM2186
Ah its nothing for e30sRM2186 wrote:Nice work Alex, coming on slowly , just the job!
Bit of a shocker finding that blob of rot.
Baz666
really nice job there Alex
tonybtonyb
loooking good.i think your water is coming in where your innerseal panel is!
is that the one above the windscreen? i keep telling him to order one but he says its not comming in there (i recon it is) but he is adiment its nottonybtonyb wrote:loooking good.i think your water is coming in where your innerseal panel is!
bmwe30mtech
Looks like a fun project. The seats have come up very nicely.
I also bought a 320i cab recently, they are not the fastest of cars are they! I will be pulling my carpet out soon also, although I havent seen a shell as solid as mine for ages.
I would leave the 320i engine in there, in my opinion cabs are for cruising about not ragging.
not much of an update but now has a new hood on it, and a new set of numberplates as the old ones were smashed.
hood cost him £200 and £250 to get it fitted which aint too bad some places want £600-£700
also hole has been welded and has a light skim of filler over the top, will get a coat of primer over the top before interior goes back in
A b25 might be going in too since we think the b20 may be missfiring because of internal problems
Nevermind a b25 is what it needs anyway
Looking good Alex
Where did you get the hood from if you don't mind me asking?
Looks good
goldysingh
my cabby has wet carpets behind the passenger seat..
did you find out where the water was coming in?
The roof wasnt fitted properly (seller told us it needed adjusting and what not anyway) so it was comming in everywhere, the hood was too far towards the rear of the car, but the roof itself had gone porus and had splits in anyway.goldysingh wrote:my cabby has wet carpets behind the passenger seat..
we will see when all the snow ontop of it melts if its 100% water tight.
Topblag
I had the same problem, I concluded that it was the roof. I gave the roof a reseal and the wetness stopped. The foam underside parts of those carpets can really soak up water in that area.
My car was getting used up to end October and it p*ssed down up here for about 6 weeks constantly in Sept/Oct.....
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
if anyone in the north east needs a hood fitting i would 100% reccomend this guy
genuine honest bloke who loves old cars, had a jag E type parked next to it in the garage getting a full resto and when we dropped the car off he was finnising restoring a triumph tr6 it was
http://www.willowtriumph.com/
its located just outside Darlington
goldysingh
did you replace the seals or were you old ones good to use?
my roof is in tip top condition with no tears but desperately needs adjusting.
anybody know of anyone in the London area who could adjust my roof?
the guy said there is no need to replace any of the seals they are all goodgoldysingh wrote:did you replace the seals or were you old ones good to use?
blackE30indy
looking good alex,definate needs a b25,
Indy
Indy
All finished now
miss fire will be getting sorted in the next few weeks, sounds very much like a snapped rocker
Ollie_bwoii
Ah you've been working on your E30 today, and I've been working on mine.
Anyway that is looking fantastic.
The BBS with polished rim? look fantastic.
Lovely. How did polish that BBS?
ive not been working on it, but i'am doing some stuff for my white CabbyOllie_bwoii wrote:Ah you've been working on your E30 today, and I've been working on mine.
Anyway that is looking fantastic.The BBS with polished rim? look fantastic.
Not sure blitz, loads of autosol and 1200 wet and dry i think
Looking good Alex, need some leatherz though
blackE30indy
Looking good alex,I think that interior soots the car
Starting to look the part now. Good work.
