What is this and what does it do?
stup86
Sat Jan 02, 2010 12:33 pm
When I bought my E30, it didn't have the standard airbox, instead it had a cone filter and look like this:
I noticed that there was a plug/lead hanging and can't find anywhere to plug. This is what I found:
It's attached to the same wire group as the one that goes to this:
Image.
So anyone know what it does and where is goes.
I think it might attach to the standard airbox.
Cheers,
Stu
Parts needed:
M40/M20 ignition coil with high voltage lead
pac1982
Sat Jan 02, 2010 12:42 pm
I think mine has a plug like this just hanging around, if your cars running fine dont worry about it
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
cass1_5503
Sat Jan 02, 2010 12:45 pm
i think its for cars with a catalytic converter doesnt go on the air box someone will corect me if im wrong
sihooker
Sat Jan 02, 2010 12:47 pm
It's something to do with emissions(charcoal filter?), probably for US spec cars..
BEERBOY123
Sat Jan 02, 2010 12:55 pm
I remember asking this a while ago and was told it wasn't supposed to plug into anything, so don't worry.
mark_i
Sat Jan 02, 2010 12:57 pm
^ correct. the plug connects to a purge valve that allows breather emissions to be collected inside a charcoal canister.
Only fitted to vehicles with catalytic converter/lambda sensor.
safe to leave hanging loose in engine bay.
Sat Jan 02, 2010 1:52 pm
If you look near the throttle body, you'll find a pipe going nowhere as well!
xavier
Sat Jan 02, 2010 2:00 pm
If you plug it into your left ear you can hear Radio Berlin
TPS
Sat Jan 02, 2010 7:03 pm
My touring has a cat. on it, & makes use of that connector, also as Brian says, a blanked off pipe on the bottom of the throttle housing on non-cat. vehicles, on mine a pipe leads to the carbon canister (I thought that was the fuel filter at first, lol)
stup86
Sat Jan 02, 2010 7:08 pm
TPS wrote:My touring has a cat. on it, & makes use of that connector, also as Brian says, a blanked off pipe on the bottom of the throttle housing on non-cat. vehicles, on mine a pipe leads to the carbon canister (I thought that was the fuel filter at first, lol)
Good to know.
Cheers.
I thought that my car would of had a cat, feel a bit stupid now as I planned to remove it!!!!!!
Parts needed:
TPS
Sat Jan 02, 2010 7:19 pm
The best way to tell is to look at the battery tray, if theres a black lead going to the exhaust, thats the 02 sensor leading to the CAT.
