Pinion seal
koos
Post Wed Aug 31, 2005 4:38 pm
Hey chaps, do I have to replace the nut on the diff pinion when replacing the seal?
Mitch
Post Wed Aug 31, 2005 11:01 pm
It is important that you DON'T replace the nut.
Before undoing anything, mark the position of the nut relative to the pinion shaft and the position of the flange.
Unscrew the nut, counting the number of turns.
Dismantle, replace the seal and reassemble.
Tighten the nut with a torque wrench set to 185 Nm for a M20 thread or 210Nm for a M22 thread.
Don't exceed these figures, and don't go past the original marked position of the nut. ABOVE ALL, DON'T GO PAST THE MARK AND THEN BACK THE NUT OFF.
Ideally, the torque wrench should crack with the nut exactly in its original position. If it cracks a small amount before this, then that is OK, but if the nut reaches its original position at a lot less torque, then the diff has other problems and needs proffesional attention (or binning).
Post Wed Aug 31, 2005 11:08 pm
There is a securing plate for the nut that has to be removed before you unscrew the nut, and that should be replaced by a new one.
M3Compact
Post Wed Aug 31, 2005 11:41 pm
Agree with Brian.
Also, you need a thin walled socket. :twisted:
SVBMW
Post Thu Sep 01, 2005 1:59 pm
Does that mean though that you should continue to tighten the nut until you reach the mark?
Tris
koos
Post Thu Sep 01, 2005 5:47 pm
Thanks Brian, have a good holiday? Seems like you're refreshed will all that info?????
Will put a post when it's done, thanks
Mitch
