318 is throttle body electrics
LeonNewton
Mon Dec 28, 2009 6:22 pm
wot are the electrical connections for on my throttle body. wot signals do thay send or receive and haw dose the throttle body generate the signal?
Yer i am sorry for my bad spelling. i am dislexic and find it just as hard to read your posts as you do mine.
DHFiS
Mon Dec 28, 2009 6:31 pm
Throttle position switch - measures now open the butterfly is. Its a variable resistor so the resistance rises and falls as the butterfly opens and closes.
LeonNewton
Mon Dec 28, 2009 6:42 pm
is that the only signal? also dose it just measure it on the big butterfly or throttle cable or dose it measure both butterfly valves independently? (if that makes sense)
DHFiS
Mon Dec 28, 2009 6:48 pm
Look on this link to realOEM for part no 2. This is the TPS.
http://www.realoem.com/bmw/showparts.do ... g=13&fg=15
LeonNewton
Mon Dec 28, 2009 6:58 pm
thanks. so thats it.
any chance anyone knows the max and min resistance the TPS creates allowing the ECU to determine wether the throttle is for fully open and fully closed?
DHFiS
Mon Dec 28, 2009 9:07 pm
Copied this from realOEM
02 THROTTLE VALVE SWITCH 4 KOHM
If that is correct the range will be from about 0 to 4000 ohms but I have never tested one on the car.
LeonNewton
Mon Dec 28, 2009 9:25 pm
ok. think that all makes sense. tar for your help. :D
