what is the "correct" lsd for a 320i?
liam012
Post Wed Aug 31, 2005 9:57 am
I know that correct is not the right term as its not standard on the 320i but i need to know the ratio of lsd to get that wont mess up the final drive of the car - if anyone knows a good place to pick them u too that would be great.
cheers
liam
Davenotouring
Post Wed Aug 31, 2005 10:01 am
Keep an eye out on here, and on eBay.
A 3.91 LSD would be fine on a 320i.
You will need to adjust the length of the propshaft though by undoing the centre collar nut because the LSD will be large case and your diff will 95% be small case.
The mounts and everything else is identical.
BMW 328i Cab - Daily Slag
liam012
Post Wed Aug 31, 2005 10:13 am
Cheers dave, can they be got new?
Giggz
Sorry to butt in but just curious what is "best" for a 325i then?
^stolen but not forgotten^
Davenotouring
Post Wed Aug 31, 2005 10:44 am
You could get one new, but it would be about a grand.
A good second-hand one will be fine.
A 3.64 is good for a 325i, good for the motorway.
A 3.73 is a perfect compromise of acceleration and cruising on a 325i.
A 3.91 is good on a 325i also, best for acceleration, bit buzzy on the motorway, but it's never bothered me.
Hope this helps. :D
Giggz
Post Wed Aug 31, 2005 10:58 am
Thats brilliant.
3.73 sounds like a good compromise like you say.
Stupid question probably...but what do the numbers stand for? :oops:
Davenotouring
Post Wed Aug 31, 2005 11:08 am
A 3.73 will be hard to come by, but keep an eye out.
The numbers are just the ratios mate.
A 4:1 ratio would mean four turns of the propshaft would create one turn of the wheels. Hence the change in acceleration and revs at motorway speeds of the different ratios.
Giggz
Post Wed Aug 31, 2005 11:18 am
OH I SEE.
Thanks for that sir.
While we are on the subject of diffs...would you recommend me changing my diff oil.I ask beacause a mechanic told me not to as my car i so old and i may jeopardise the running of the diff????
jaistanley
Post Wed Aug 31, 2005 11:19 am
I have just bought a mega rare (in england anyway) 4.1 big case LSD from an american M3. As my car is a 318is and has very little low down torque I felt a 3.91 would kill the acceleration.
Does a 320i have the grunt for a 3.9. They're specced with a small case open 4.1 like my original diff aren't they?
Jai
Toby_Unna
Boost Junkie
Post Wed Aug 31, 2005 11:25 am
BLATANT ADVERT!!
i have just swapped my 3.91 LSD for a 3.64 LSD
the 3.91 is for sale and it's a good 'un!! perfect for a 320i as Dave says.
http://www.e30zone.co.uk/modules.php?na ... ic&t=16266
Toby
Davenotouring
Post Wed Aug 31, 2005 11:50 am
Yeah you should change the oil, but use proper LSD oil, get it from the dealer. You need to take a container there, get two litres.
Tobys diff is a good one, buy it.
A 320i will be fine with a 3.91, mine was.
