Alpina B10 3.5
pauldeacs
Right ive just been offered the follwing engine and box from my mate to put in my 325i. do you think its worth the Ԛ£500 he wants lol................
Genuine Alpina B10 3.5 engine, needs new head gasket (with paperwork to prove authenticity of engine)
Dog leg box
Air flow meter
sadly no loom or ECU though
if im correct these engines are 263bhp.
Dog leg box
Air flow meter
M5pilot
get it! Ԛ£500 is a giveaway price. 260 odd bhp, cant remember what Alpina quote but it will make a bloody fast E30.
Dont worry about loom and ECU, just use one from a 535i. Unfortunately you wont have the Alpina Map in there but seeing as your getting it so cheap just get a MAF conversion done and it will be even more torquey and powerful.
glenn
- Engine Transplant Services
i'd say get it.
but i like bigger engines
Karan
worth it if 'only' the head gasket is gone...
id wanna remove head and inspect bores and head for cracks
id also wanna remove the sump and use a plastigauge to measure shell wear....
otherwise its not worth it, cos if it needs rebuild it will cost u about 1.5kin all after uve rebuilt the bottom end, and thats not taking into account the fact the head may be cracked.....
and for this price u could have the much better e36 m3 evo engine or maybe an e34 m5 engine... both with in excess of 300hp.... and these are ///M engines
Kedge
GET IT!!!
Performance figures are something like, 0-60 in 6.5secs and tops speed of 165mph IRC
Just missed out on one of these myself which was even cheaper and had everything, proper gutted
pauldeacs
Ai deal is near on done, the chap bought the engine and box about a year ago to put in his sport but has never bothered.
Who offers the best price on engine mounts for this engine in an E30? ive seen various names/sources bounced around on here
Karan
assuming the engine is from an e34 5 series.... i can make u a set for Ԛ£130 in 10mm steel for positions 2 or 3.... i have had them copied from mounts from germany,,,(Ԛ£170)pauldeacs wrote:Ai deal is near on done, the chap bought the engine and box about a year ago to put in his sport but has never bothered.
pauldeacs
yeah right i would check it over first. I have a mate with a B10 Bi turbo and hes just blown a piston on it, looking at a wait until december just to be able to get a new piston from Mahle. nightmare i could do without.Karan wrote:worth it if 'only' the head gasket is gone...
Buying any second hand engine is a gamble i guess
Karan
unless u buy it running in a car, or heard it runpauldeacs wrote:yeah right i would check it over first. I have a mate with a B10 Bi turbo and hes just blown a piston on it, looking at a wait until december just to be able to get a new piston from Mahle. nightmare i could do without.Karan wrote:worth it if 'only' the head gasket is gone...
pauldeacs
still a gamble even then. I know 2 people who did hear/see it running before removal but like you said il have to have a good look at it firstKaran wrote:unless u buy it running in a car, or heard it runpauldeacs wrote:yeah right i would check it over first. I have a mate with a B10 Bi turbo and hes just blown a piston on it, looking at a wait until december just to be able to get a new piston from Mahle. nightmare i could do without.Karan wrote:worth it if 'only' the head gasket is gone...
Andy335Touring
If its got a dog leg box won't that make it an e28 engine ?
pauldeacs
does an e28 engine not fit?Andy335Touring wrote:If its got a dog leg box won't that make it an e28 engine ?
Geeman
An E28 engine wioll make it a B8 then, as opposed to a B10...
Simon
And if it's an alpina engine and the head is knackered, and you want to replace the head with a proper alpina head, good luck!! New one is on the near side of 1.5k.
Toby_Unna
- Boost Junkie
noooGeeman wrote:An E28 engine wioll make it a B8 then, as opposed to a B10...
you can get an e28 b9 and a b10, the b9 is 245 and b10 around 260 i think
and a b7s and other crazy turbo versions
dunno what version a b8 is though
e28 will fit with a few bolt-on mods
pauldeacs
Bolt on mods in term of what? Im rapidly going off this ideaToby_Unna wrote:Geeman wrote:An E28 engine wioll make it a B8 then, as opposed to a B10...
Andy335Touring
I think E34 M30 sump and oil pump pick up, Toby will confirm if this is correct as he started off with an E28 M30.pauldeacs wrote:Bolt on mods in term of what? Im rapidly going off this ideaToby_Unna wrote:Geeman wrote:An E28 engine wioll make it a B8 then, as opposed to a B10...
Toby, hows the new dif going, does it feel good !?
Toby_Unna
- Boost Junkie
fcuking great! won't quite do 60 in 2nd (very nearly) but will sort that out!
firstly the sport box ratios are going in the current box
secondly i will get that chip sorted and working properly, and that takes limiter up to 6500
but yeah generally the diff is great!
re the e28 engine:
firstly you're stuck with an e28 manual gearbox because the engine uses sensors on it, so if the dogleg breaks/is already worn (common) you're in trouble.
the e28 engine also has a water cooling pipe on the back of the head unlike the e34, not major but does demand more bulkhead hammering
exhaust manifold less well suited to e30 (yours might be tubular though, but that won't fit easily either)
electrics less well suited (have to cut off engine plug and solder e30 one on, whereas e34 engine essentially plugs straight in with no soldering.
need e34 sump and pickup as Andy said.
hard one to call but for an e30 conversion i think i'd lean towards a really good, guaranteed e34 535i engine/box for that sort of money, unless you're prepared to pour a lot more in later!
re the e28 engine:
