rack conversion..
CHR1S1990
yes! if i am stationary at idle, it is really heavy, however if i increase the revs the PAS seems to work.
CHR1S1990
^ this definitely seems whats going wrong, but not sure why its happening! PAS will only work at say aove 1500rpm. If the rack is fine, and new fluid, and the belt looks ok and isnt slipping, the pump fubared? Cant think what else.
Thanks, chris
Thanks, chris
StuBeeDoo
CHR1S1990
that's what i thought, so i readjusted the trackrods, and now it drives fine, but the trackrite still keeps coming apart. i'l give it another go once if got the rack sorted.cheers
CHR1S1990
how hot should the fluid normally get? the reservoir is pretty damn hot. if the fluid boils, how will it steer? not sure why it would boil thought as i have a cooler fitted and my pipe from the rack to the pump runs around the front of the car anyway. just pulling at straws now really!
chris
chris
e301988325i
ok, it sounds like your fluid is boiling, what are you using?
Your fluid is obviously doing what mine did with no cooler, boiling then steering jams, when you're driving along I'm guessing it gets enough airflow to cool down and work properly.
I had to flush the system out twice with new oil to get it working properly again. once the fluid has boiled it's knackered, even letting the car cool down completely my steering didn't return to noraml until new oil was in there.
Or it could be a blockage and the pump is working overtime. . .
Just to confirm, can you give a detailed description of your pipe runs, cooler position, reservoir position anything that may be of interest.
I bet you're tearing your hair out LOL. I went through this in Germany, with only the tools I could carry, and my German is far from 'my power steering fluid is boiling, help'.
I said:
e30topless said:
lock the wife in there
CHR1S1990
lol thats bad! im having troubles on my driveway let alone in another country...love to know how you sorted that one out!
the reservoir is on the bulhead, just to the right of the inlet manifold. pipe from there to the pump is original and untouched..the pipe to the rack is the original e30 item, but bent and follows infront of the sump (my attempt at trying to get some extra cooling)...the return pipe from the rack to the reservoir is the e46 item which seemed a lot easier for me to straighten and sits just below the rack, then the flexi hose goes to the cooler behind the grills, then from the grills back to the reservoir.
I also think it has something to do with the fluid. What colour shoud the fresh fluid be? To be honest, i didnt flush the system like i should - just wanted to get it working, i didnt expect it to be like this! ATF dextron II/III is the correct stuff correct? How much is needed to flush and fill? Il go and get another batch tomorrow. My symptoms sound similar to that of my sisters a while back...she has an e36 318ti, and she filled the PAS reservoir with PAS fluid, not ATF dispite being told otherwise. What happens if the wrong grade fluid is used e.g. PAS fluid as opposed to ATF? Whats the difference between the two?
chris
chris
e301988325i
The capacity is just under a litre, ATF dextron II is the stuff. II/III may be different. Mine was a transparent red when new, goes milky then black when knackered. I definitely put ATF dexron II in mine.CHR1S1990 wrote: I also think it has something to do with the fluid. What colour shoud the fresh fluid be? To be honest, i didnt flush the system like i should - just wanted to get it working, i didnt expect it to be like this! ATF dextron II/III is the correct stuff correct? How much is needed to flush and fill? Il go and get another batch tomorrow. My symptoms sound similar to that of my sisters a while back...she has an e36 318ti, and she filled the PAS reservoir with PAS fluid, not ATF dispite being told otherwise. What happens if the wrong grade fluid is used e.g. PAS fluid as opposed to ATF? Whats the difference between the two?
chris
Are any of the pipes particularly close to the downpipes?
I said:
CHR1S1990
okay dextron II it is. Nope, non are in particularly strange conditions, not are kinked! I opened the reservoir this morning...and it's empty!. No leaks on the floor..im assuming the fluid has totally boiled! Will it nacker the pump to run the steering without any fluid in?
e301988325i
It's not all in the rack boots is it? If not, then it would suggest that your system wasn't bled, as I don't think it will boil off like water. The pump will not be happy without fluid.
If you need to drive it remove the belt.
I said:
CHR1S1990
doing exactly that now...going to remove the belt then go get some more ATF...i rang up my local motor factors and they quoted me 11quid for 6 gallons of ATF! this guy must be taking crazy pills.. lol
Dave_M3
For 11 quid for 22Liters, I'd say nothing!
Thats enough fluid to flush and re-fill the system 10 times
I'd go with a proper flush to begin with anyway. Could be that the oil-cooler or hoses could be gunked up if they were off for a while and lying somewhere.
N00b
I'd say less than nothing then, as it's approx 27 and 1/4 litres ;)Dave_M3 wrote:For 11 quid for 22Liters, I'd say nothing!
Messenjah
how much is a complete e36 rack conversion worth ?
CHR1S1990
well - i flushed the system with 4 litres of new ATF, and then filled with a final litre. Start it up again to bleed the system of air and what happens? The steering pump starts pissing the new ATF everywhere. Tightening the bolt up near where the leak is occuring has no affect whatsoever. So as i dreaded, they pump is buggered! Can you buy new seal kits? Or is it just worth getting another pump? How much do they go for? Not sure why it has decided to go, though.
Chris
Chris
Just get another pump, ive never had any overheating with my E46 rack in over 2 years, but ive never used it on track either
e301988325i
s/hand pumps are next to nothing £15 should get you one, new they're probably very expensive. At least you've found the problem.
I said:
CHR1S1990
indeed! and spot on! just got one for 15quid posted and looks very tidy! had some very strange noises coming from the front end so i suspect this is what it was! not had a gud day really, and ATF dripping from the reservoir in my hair just topped it off! Theres no fluid in the boots on the rack, so hopefully the rack is fine. Will I need to reflush the system when i get the new pump?
Chris
Chris
e301988325i
wouldn't hurt, it may be bits of pump blocking things up
I said:
e301988325i
CHR1S1990 wrote:lol thats bad! im having troubles on my driveway let alone in another country...love to know how you sorted that one out!
I said:
CHR1S1990
explained beautifully, and you didnt even move your mouth! lol..what a nightmare that must have been. good job you had your tools! just awaiting my replacement PAS pump now, and got a new v belt from ECP (may as well for only 4quid). Will replace the pump, re flush, bleed, and let you know what happens.
chris
chris
Dave_M3
Could have been worse.... could have been pissing rain like it would have been here in Ireland or the UK
Let us know how you get on Chris
CHR1S1990
well, i think nightmare is an understatement. Fitted replacement pump today, re flushed, fitted new belt, re bled. And it worked brilliantly, for the 10 minute drive from my mums house back to mine. Got back and i reversed into my drive as always, and the steering was stiff again with no PAS. The belt is tightened up properly, and ive checked the boots on the rack and theres no fluid so the seals should be ok. Took the lid of the reservoir to check the level, and it is about right - however in the space of 10 minutes its gone from red to blacky/grey. Boiled?
e301988325i
all i can suggest is re-flush two or three times, otherwise something needs replacing.
I said:
e301988325i
It does change colour once knackered. 'Dirty' fluid in the reservoir suggests that you've got circulation of fluid. It may be contaminated from the last lot, I had to flush a couple of times.CHR1S1990 wrote:however in the space of 10 minutes its gone from red to blacky/grey. Boiled?
I said:
CHR1S1990
i flushed it with my first pump with 4 litres of atf (until it went red)...and then with the new pump today only took 2 litres for it to go red..there must be something i'm missing!
CHR1S1990
fluid is defo circulating. strange happenings...took it for a 20min drive before, and drove perfectly. only seems to do it when immobile for a lengthy period
DHFiS
If you want to know how hot your fluid is getting stick a heat sensitive label to the reservoir.
http://www.frost.co.uk/item_Detail.asp? ... g%20Labels
CHR1S1990
been for an hours drive today and all is fine, there must have been some kind of blockage? Anyway, im convinced this is not a sport rack. The steering is extremely light, maybe its just because ive gone from non PAS to PAS, however the numbers on the rack match that exactly of those given alex.
e301988325i
did you use the banjo bolt from the e30 rack? I'm wondering if the E46 banjo bolt restricts the flow to give increased resistance, if the lock is 3.0 turns then it must be a sport rack.
Define extremely light, a standard E46 rack will only need 1 finger to dry steer on dry tarmac. with mine it's a good grip with one hand to dry steer (although obviously I avoid this unless 100% neccessary)
I said:
CHR1S1990
I used a mixture of the bolts as far as i can remember, but one of the bolts did have some sort of restrictor in, one i put on yesterday on the pump but not sure which one it was. Il have a look now at the bolts i have left. From lock to lock on the steering wheel, it seems about 1/5th of a turn shorted than 3.0. what would a non sport rack be?
dry on my drive, I can turn it with my finger - but it does hurt. lol
e301988325i
Dave_M3 wrote:But its 3 turns lock to lock?
normal E46 rack is 3.4
I said:
CHR1S1990
it's nowhere near 3.4. and the numbers are identical - its the last number of the part number which differes is it not? i know monkey had 068 and he didnt have a sport rack, but mine is 067. so perhaps it is the bolts? will there be any visual indications as to which bolts are the e46 item as opposed to e30?
StuBeeDoo
I've been watching this thread from day 1. Interesting reading. I'm planning a quicker rack in my touring when the standard one finally runs-up the white flag.
If it is, I've gotta get me some of that!
Are you saying, then, that your rack is 2.8 lock-to-lock?CHR1S1990 wrote:From lock to lock on the steering wheel, it seems about 1/5th of a turn shorted than 3.0.
e301988325i
it is definitely under 3.0
I said:
