rack conversion..
Dave_M3
Post Sun Nov 29, 2009 9:58 am
But its 3 turns lock to lock?
normal E46 rack is 3.4
N00b
Post Sun Nov 29, 2009 11:02 am
Dave_M3 wrote:But its 3 turns lock to lock?
When your starting point is the standard e30 rack (4 turns L2L I believe) then three point anything is an improvement, lol.
Post Sun Nov 29, 2009 11:11 am
Dave_M3 wrote:
Other reason is the guibo is a shear point on the column in the event of a crash so the whole column doesn't push the steering wheel on top of you.
Didnt make any difference to my henna red chromie when I bent it, the column sheared and it came backwards. Also cut my legs as I got thrown out
When I changed from an E36 rack to an E46 rack I was using a standard E30 PAS linkage with the rack mounted in the forward holes, I didnt need to do anything to the linkage, the clamp bolt went through exactly the same, I just had to trim down the plastic bit that surrounds the input shaft.
Overall the E46 rack gives much better steering, even though its the same amount of turns lock to lock it feels like it steers a lot quicker/more responsive
N00b
Post Sun Nov 29, 2009 1:59 pm
Right, so to clear things up let's see how much I've learned.
The rack I want is a 330 clubsport rack, which we believe has the part number "6 755 067"
The rack bolts into the forward holes on the standard e30 cross member, but needs spacers. Why, and what exactly makes up a spacer? Are we talking a washer under the rack to raise it for some reason?
e46 boots are used with e30 track rod ends.
No "guibo" is needed to fit it as the linkages are long enough to be bolted together.
An oil cooler is needed for this rack.
Any errors or ommisions in the above so far fellas?
e301988325i
Post Sun Nov 29, 2009 4:37 pm
:o:
I used two 7.5mm spacers (washers effectively) each side, one above one below.
I said:
e30topless said:
lock the wife in there
N00b
Post Sun Nov 29, 2009 6:22 pm
:o:
7.5mm (thickness I presume) washers eh?
Why do they need to be used ie what do they do?
e301988325i
Post Sun Nov 29, 2009 6:31 pm
Where the rack attaches to the car, the E46 rack is 15mm shorter than the E30 rack.
I said:
Dave_M3
Post Sun Nov 29, 2009 8:06 pm
I have 8mm and 6mm spacers which put the rack in exactly the same place as the E30 rack is.
Have 7.5mm ones too as well as 14mm depending on what people want.
Re: Dan; yeah, the E46 rack fits fine with the standard guibo too but it shoved the upper U-J right up against the bulkhead on mine so I just removed it as there was enough meat on the splines for it.
Your chromie had quite a knock from the looks of it so I doubt any bit of rubber was going to make much of a difference :P
Lucky man to be still here though!!!
N00b
Post Sun Nov 29, 2009 8:27 pm
Dave_M3 wrote:I have 8mm and 6mm spacers which put the rack in exactly the same place as the E30 rack is.
Would these give different amounts of clearance depending on their choice of engine/exhaust, or are there other reasons for favouring different spacers?
GeoffBob
Forced Induction Specialist
Post Mon Nov 30, 2009 7:04 am
Details of how I fitted my E46 steering rack with pics here
Same part number as indicated by e301988325i
N00b
Post Mon Nov 30, 2009 12:20 pm
Did you also fit a cooler for the rack?
Good read btw, and extremely well presented. The added pics make it much easier to understand the problems involved.
GeoffBob
Post Mon Nov 30, 2009 1:55 pm
N00b wrote:^^^
Thanks for the comment Noob.
No cooler with mine, but I haven't ruled out that I may well have to fit one at some point. Using the PAS pump with my Toyota engine, so not exactly BMW. Will definitely fit a cooler if I see the Toyota PAS pump heats the fluid beyond acceptable.
N00b
Post Mon Nov 30, 2009 8:37 pm
GeoffBob wrote:Thanks for the comment Noob.
My pleasure.
Some of the guys in here sometimes forget that not only have they accumulated an enormous amount of experience on the e30, but that some stuff they've discussed a million times might still need explaining to people who just found this place.
I only just found out what a BBTB was, and I still don't know where to get one from or exactly what it would do for my engine, lol.
Dave_M3
Post Tue Dec 01, 2009 1:28 am
BBTB is just an overbored standard throttle body.
Can get one from Evo-S or one or two members on here like me, Kev (can't remember his full username) and I think somebody else makes them up on an exchange basis at around a 100 quid.
As for what they will do for your engine, not a huge amount to be fair considering the original prices were well over 200 quid but they do improve throttle responce alittle bit so every little helps and all that :)
Having the 14mm spacers above, below or 6/8 either side of the rack when mounted on the E30 subframe is all about clearance to the sump, manifold and steering geometry.
I have mine on the front holes with spacers above the rack as it gave me the best clearace for the sump and manifold with the E36 rack.
The geometry of the track rod ends and control arm may not be perfect but I haven't really experienced any bump steer issues if I'm honest once the steering alignment is right.
I must try the 6/8 mm spacers though to see if theres enough clearance as there wasn't with the 14mm ones underneath
Barx325i
Post Tue Dec 01, 2009 5:13 pm
Dave_M3 wrote:BBTB is just an overbored standard throttle body.
Only an m42 owner can appreciate the meaning of throttle response :)
OT, Is it necessary to find a 330 clubsport rack or will a standard rack suffice? I am about to purchase some hardware & found a decent 323 rack..
e301988325i
Post Tue Dec 01, 2009 5:17 pm
It will fit, but not worth the effort in my opinion, just be patient. Especially considering I got my rack for £60 delivered and the OP got his for £85 delivered.
I said:
CHR1S1990
Post Wed Dec 02, 2009 12:56 am
got the rack today btw (and rear disk setup, woo) will be fitting next week when i break up from uni. cant wait to see the results! will add sum pics etc if it helps anybody
chris
CHR1S1990
Post Sat Dec 12, 2009 10:13 am
hi guys
so i set about fitting the rack yesterday - changed the tie rod ends and track rod ends for e30 parts - no problem. Ive fitted it in the front mounting holes, and i bent (with a lot of swearing) the original e30 pipes to shape. However, using the standard e30 UJ, it catches the exaust! It is only very slight, but enough to cause problems. Any ideas? I thought it was possible to use this combination? i.e. front mounting holes and standard e30 UJ.
any help would be great, need to try and get it sorted today
cheers
chris
CHR1S1990
Post Sat Dec 12, 2009 10:30 am
just to add, reason i tried to use the e30 guibo is that i only got the lower half of the e46 item..is there any way of making an e30/e46 combination to fit? m20b20 engine btw..
thanks!
chris
CHR1S1990
Post Sat Dec 12, 2009 12:46 pm
bump...going to go and have another crack at it now
anybody done this conversion on m20 using e30 guibo?
thanks chris
Dave_M3
Post Sat Dec 12, 2009 3:32 pm
Remove the guibo and bolt both E30 U-Js together.
I've done it this way on two Sports with an E46 rack.
CHR1S1990
Post Sat Dec 12, 2009 9:51 pm
so drill the rivets out and remove the rubber part and both the two halves together? wouldnt that make it shorter..would i need some sort of spacers inbetween? any pics?
thanks again
chris
Dave_M3
Post Sat Dec 12, 2009 10:09 pm
Yes, makes it shorter but E46 racks pinion is alittle longer though ;)
Barx325i
Post Sat Dec 12, 2009 10:11 pm
that's right, It will straighten the assembly slightly and then won't foul the manifold (apparantly)
I haven't got any pics though sorry
CHR1S1990
Post Sat Dec 12, 2009 11:38 pm
thanks guys, will give this a go tomorrow
ive taken it for a drive anyway as it was only brushing the exhaust - it does give an old car great feel. however, ive filled up with new fluid, and it drives as it should at higher speeds but at low speeds or on the spot, it is very juddery and feels as if there is no PAS at all and is very hard to turn
any ideas? ive tried bleeding it after putting just less than a litre in, but the level doesnt seem to be changing.
thanks
chris
Dave_M3
Post Sat Dec 12, 2009 11:42 pm
Is it a Sport rack or normal E46 rack?
CHR1S1990
Post Sat Dec 12, 2009 11:44 pm
sport rack as far as i know, the numbers on the case matched that exactly of those e301988325i posted up at first
Dave_M3
Post Sun Dec 13, 2009 1:42 am
you got a oil-cooler, yeah?
CHR1S1990
Post Sun Dec 13, 2009 10:19 am
yeah, fitted it up front behind the grill. i take it this would affect the steering if become too hot? i.e. when not moving...how much hotter will the fluid get on the e46 rack compared to the e30 one? at present its just an absolute nightmare to park..
thanks
chris
e301988325i
Post Sun Dec 13, 2009 1:24 pm
When my fluid boiled I had the same extreme resistance as you describe, a couple of flushes later, back to normal.
Anyone, would it be a problem if the hoses on the bottom of the PAS reservoir where connected the wrong way around?
Any luck today?
I said:
CHR1S1990
Post Sun Dec 13, 2009 1:35 pm
hmm, the fluid level had dropped considerably this morning so ive topped it back up. As regards to the reservoir, i only removed the return pipe so they should be the wrong way round, but im sure ive read on here somewhere that they must be the correct way round? The tracking is massively out which is expected, but it still feels very stiff at idle and i littery have no PAS. Ive checked the pump v belt and it doesnt look damaged and it is tight enough, however it does seem to look a little wet. Perhaps making it slip on slow revolutions?- there is no slipping/squeeking sound though..
really not sure what to do now!
e301988325i
Post Sun Dec 13, 2009 2:07 pm
PAS oil on the belt and pulleys?! new belts are pennies. . . and pas is corrosive stuff
Jack both front wheels off the ground and see what the resistance is like with no load on the tyres. run the engine, turn from lock to lock to bleed the rack fully. Sounds like you're having a bit of a knightmare!
I said:
CHR1S1990
Post Sun Dec 13, 2009 2:12 pm
i am having a massive nightmare! i dont think its PAS oil, i think its engine oil - theres been a very slight leak for a while now which ive been turning a blind eye to whilst i prep for new engine. I just thought, i had to relocate the reservoir to a different place (lower than it was) due to needin the space on the strut for a valve on the LPG kit, could this be a causative? - the rack is gravity fed isnt it, and the e46 required higher pressure? Il give the pump pulley and belt a clean now, and jack it up and see what the resistance is like as you said.
thanks
chris
e301988325i
Post Sun Dec 13, 2009 2:32 pm
Oil on the belt isn't going to help, so that's a first job.
Even though the belt may not be slipping at idle with the wheels straight. The rack requires more pressure from the pump once the steering wheel is turned, so the belt may be slipping under load.
The fact the rack is ok at when at speed suggests the rack is ok to me. with high engine rpm do you gain assistance when the car is stationary?
The pump's supply is gravity fed, and must be lower than the reservoir, however as long as the pump gets a supply of oil this will have no bearing on the hundreds of PSI the pump is capable of making.
I said:
CHR1S1990
Post Sun Dec 13, 2009 2:33 pm
just jacked it up and it seems to be running fine with no load on the tyres.. also need to sort the tracking out, bought one of these trackrite things but it doesnt seem to like me much! as i drive over it, it slides off too far and the needle comes out..the wheels are pointing near as damn in the same direction and it is driving ok so il leave it for now. just need to sort the guibo out but more importantly this PAS problem! it seems to be intermittant (except for it being irregular) - sometimes on the spot it will work fine with PAS, others the PAS seems to fail alltogether and is stiff as...
