The Diddler's Resto ** NEW PICCIES** 10/10/12
Post Fri Oct 30, 2009 1:15 am
Good work there Paul, good to keep yourself busy.
If you need a hand give me a bell.
Oh and go for the Alpina look, defo :cool:
The_Diddler
Love it up the more door !
Post Sun Nov 08, 2009 5:34 pm
Update Sun 08/11/09
Well DanThe popped around today to get things progressed, engine now removed along with gearbox, prop and exhaust. ABS pump removed too, wont need that anymore, need to get that brake servo out as well, its a little too big !!! winkeye.
Need to degrease engine bay and remove a few more bits and pieces before hopefully it goes to the bodyshop in a few weeks time.
I'll let the pictures do the talking.
New drivers side wing and bootlid fitted thanks to dave318 for the parts and DanThe for getting them when he popped down to see Dave, my bootlid and wing were looking a bit too crusty in places for my liking :D :D
Heres home for both the moredoors, you can see the 84 moredoor nice and snug under the covers, dont worry it hasnt been weighed in, just waiting its turn :D :D
Thats all for now, busy day today, thanks again Dan :thumb:, not much to remove now then its time for paint, thats the next job to get done :)
Post Sun Nov 08, 2009 6:09 pm
M52?
Post Sun Nov 08, 2009 10:04 pm
You get yourself a hoist?? :cool:
djk
Post Sun Nov 08, 2009 11:02 pm
Hmmmm.... Danthe assisting..... Got to be a twin cam....... could it be a tuned iron block b28 of certain provenance???
Fair play Paul, doing things so properly it hurts.
Post Mon Nov 09, 2009 6:30 am
bss325i wrote:M52?
S50????
town325i
Post Mon Nov 09, 2009 9:14 am
Rav335uk wrote:You get yourself a hoist?? :cool:
i lent dan mine
SUMPCRACKER
Post Mon Nov 09, 2009 10:28 am
Your a special person Didler, only some can do what you have.
You made me want a red moordoor! 8O
A lovely car, getting lovelyer. And i will mention, its unusual for a car to look better in the fleash than in pics, which this does, at DC09 show i was well taken with it. :cool:
Post Fri Nov 27, 2009 10:06 pm
Any updates yet????
The_Diddler
Post Sat Nov 28, 2009 4:47 pm
Update 21/11/09
Things have moved on a tad now, need to really as the moredoors booked into the Bodyshop from the second week in jan 2010 8O 8O
As i've got plenty of time until then :cry: :cry: , the underneath will be getting some attention, so off with everthing underneath to make way for:
New fuel lines, clips etc
New brake lines, clips etc
New heatshields, nuts, bolts etc
New fuel tank, nuts, bolts etc
New handbrake cables, nuts, clips etc
Suspension getting completely overhauled, new rubber, stabilisers, nuts, bolts, clips etc.
New set up will be Bilstein B12 kit for the front and back
New brake backplates, wheel bearings, discs, calipers and arms going for overhaul to make minty mint again
Rear beam, trailing arms, ARB's (Front 20mm, Rear 14.5mm), fuel filler neck all away for powder coating along with some front struts, Front cross member already done and waiting fitment of a minty E36 steering rack.
Had a litle help from a fellow zoner on, to move things on a bit, guess who.......?????
A few underneath which is now ready for cleaning, and spruce up 8O :cry:
This will involve locallised repairs to anywhere the original BMW body underseal has become split/compromised and affected by a tad of the dreaded rust, process will be:
Clean area with wire brush in drill to clean metal, apply rust treatment, paint with red oxide, apply seam sealer etc, then paint the complete underside black, easy....................... 8O 8O
Underside as of Friday afternoon before cleaning commenced
Update tomorrow with hopefully a nice clean underside.... :D :D
Post Sat Nov 28, 2009 5:04 pm
Good grief diddler you don't do things by halves do you !
Can't believe you've pulled apart a car which already was cleaner than most of the E30's left on the roads 8O
Looking forward to seeing the finished product - hope you're gonna pull your finger out with the Henna one soon :wink:
Post Sat Nov 28, 2009 5:10 pm
that little lot will make it 'as new' underneath
Superb work Paul, your going deep on this one ! :D
keep the piccies coming :wink:
Post Sat Nov 28, 2009 9:37 pm
DanThe?
Looking good Paul, keep the updates coming :thumb: :cool:
djk
Post Sun Nov 29, 2009 8:49 pm
Indeed, I spy Dan H's bonce in thy engine bay. Fair play paul, you are a psycho, but in a good way. When you're bored of your two moredoors, can I deposit mine on your drive and write a cheque? Do enlighten us on the engine plans - am I right? M5X hybrid?
The_Diddler
Post Sun Nov 29, 2009 10:09 pm
For those eagle eyed amongst you, it is indeed Dan H, fiddling in the bay :D :D :D :D
The_Diddler
Post Mon Nov 30, 2009 8:50 pm
Little update nearly finished cleaning the underside now, not that many areas need attention, but those circular jobbies in the rear footwells and boot well look a bit crusty, will find out more when scrapping commences :( :( :D
Great news thou today, car now has confirmed booking at Beardmats body shop on 11th Jan 2010 woohoo........ :cool: .
Just need to get my finger out, get the underside sorted and rear beam back on after refurbishment, that little lot will keep me busy for a while over Christmas.
Here's a few piccies of the underside after cleaning......
Thats all for now.
Just purchased today some wire wheels for me drill, some zinc primer and some seam sealer, mind i might swop the zinc primer for etch primer instead now after talking with another zoner.
Post Mon Nov 30, 2009 8:59 pm
great stuff , I have all this to do .... :(
Paul what did you use/method to clean it underneath ?
Post Mon Nov 30, 2009 10:03 pm
Top job! Pressure washer in the garage FTW :thumb:
I see you have some of that nasty underseal around the spare wheel well :cry:
Post Mon Nov 30, 2009 10:25 pm
Good work Paul. I'm ordering all my bits very soon. I'm going all the way as well. Restored one drive shaft today. Well it's a start!
Post Mon Nov 30, 2009 10:33 pm
You amateur Trevor, Paul is ordering new drive shafts :)
The_Diddler
Post Mon Nov 30, 2009 10:38 pm
DanThe wrote:You amateur Trevor, Paul is ordering new drive shafts :)
:D :D
DanThe wrote:I see you have some of that nasty underseal around the spare wheel well
Thats what i thought, however its just black paint, probably to hide the wheel well from view, no horrible underseal to remove, just plenty of crap to wash off :( :(
Post Mon Nov 30, 2009 10:39 pm
:D :D
that's cheating !
The_Diddler
Post Mon Nov 30, 2009 10:49 pm
e30topless wrote:great stuff , I have all this to do .... :(
Combination of Meguiars Super Degreaser
http://www.elitecarcare.co.uk/meguiars- ... p?cPath=48
and this Surfex HD All Purpose Cleaner/Degreaser
http://www.elitecarcare.co.uk/surfex-hd ... p?cPath=48
50/50 mix with water did the job with various old paintbrushes, washing up brushes(bristles a bit stronger), and old toothbrushes, ohh and lots of scrubbing........
blackcountrybimmerman
Post Mon Nov 30, 2009 11:31 pm
Go for it Paul. It will be well worth it when it's finished.
Nice attention to detail there mate.
It doesn't look like it does in my sig pic anymore
Post Tue Dec 01, 2009 7:08 am
e30topless wrote:
:D :D
that's cheating !
:mad: .
Certainly came up well Paul. I'm using a strong TFR mix and then after a degreaser.
Felix79
All loved up !
Post Tue Dec 01, 2009 1:48 pm
Paul your a sick sick man! Also Dan you bugger saving a mooredoor you Deviant!
I must admit that I found it really intresting seeing all underneaith thee car like that. Now Paul if your engine modding her what on earth are you doing with that low milage m20 of yours?
Felix79 aka Dan
E85 Z4M Roadster
The_Diddler
Post Tue Dec 01, 2009 7:43 pm
Felix79 wrote:Now Paul if your engine modding her what on earth are you doing with that low milage m20 of yours?
I still have my "A" Reg 84 henna red Chromie you remember, and that 2.7 block from the 525E, ohhhh what shall i do winkeye winkeye
Felix79
All loved up !
Post Tue Dec 01, 2009 7:49 pm
Last time we spoke about it you were thinking of doing a moredoor copy of mine? Which would be pretty cool to do.
either way your a deviant but I do look forward to it all. I'll have to pop up sometime Paul as I love to have a cuppa and a natter about th eprojects. Oh then do my engine bay for me :D
Felix79 aka Dan
E85 Z4M Roadster
Felix79
All loved up !
Post Tue Dec 01, 2009 8:24 pm
Paul I've had a bit of a brain wavey thing. Can you gete some really really good pis of the tyre pressure stickers mate. I have an idea which might help a fair few of us pina owners out ;)
Felix79 aka Dan
E85 Z4M Roadster
The_Diddler
Post Tue Dec 01, 2009 8:38 pm
Felix79 wrote: I'll have to pop up sometime Paul as I love to have a cuppa and a natter about th eprojects. Oh then do my engine bay for me :D
Anytime matey, your more than welcome :D :D
Felix79 wrote:Paul I've had a bit of a brain wavey thing. Can you gete some really really good pis of the tyre pressure stickers mate. I have an idea which might help a fair few of us pina owners out ;)
Will do, It'll have to be tomorrow now, i'll try and get some decent shots.......
Felix79
All loved up !
Post Sun Dec 06, 2009 4:52 pm
Cool as Paul buddy.
Going to see if our vertically challanged MOD will be able to make some copies up for the Alpina boys.
Felix79 aka Dan
E85 Z4M Roadster
Post Sun Dec 06, 2009 5:54 pm
Felix79 wrote:Cool as Paul buddy.
Will genuine alpina receipts/documents have to be provided to allow purchase, or can any scummer have one? :)
Felix79
All loved up !
Post Mon Dec 07, 2009 1:06 am
Does this look like North Oxford garage parts desk?
Saying that I think the Alpina needs a full stirp and rebuild on the engine or I am seriously thinking about getting a B6 engine of some description put in it.
Felix79 aka Dan
E85 Z4M Roadster
The_Diddler
Post Sun Dec 13, 2009 9:39 pm
Little update for you......
I took the wire wheel to any signs of split factory underseal/rust.
Lots of little repairs, However its amazing how far the rust spreads underneath once the underseal splits 8O 8O
Heres a few after:
1. Remove old underseal, grind rust down
2. Apply "Krust"
3. Apply Zinc Primer
4. Apply Seam Sealer
Ignore the bottom of the arch, move along no rust to see here!!!!!
And a couple after having a play with some primer, lots more to get painted and finished :D :D
Still lots to do underneath, before all the new goodies can be fitted winkeye
Good day today got loads done, so as i am retro-fitting A/C out with all the interior, dash and heater box 8O 8O
Knew these were fooked, new ones coming from stealers
Yet another hole for Matt to fix, exact size as the square factory jack pad, hope he isnt looking at this thread yet :( :(
So, only 4 weeks until its off to the Bodyshop, need to get underneath 90% finished, Matt hopefully will sort the rest, and get new rear suspension fitted so we have a rolling shell
Thats it for now :D
Post Sun Dec 13, 2009 9:45 pm
Pimpin :cool:
