EXHAUST
chris_335
Post Fri Nov 27, 2009 6:57 pm
hi all just wanna know what size tube i should use
and what size box i was going to use my old cherry bombs
but not to sure yet can you help
Pic's
kms_racing
Post Fri Nov 27, 2009 10:57 pm
im using a twin 2.25" 500x300 powerflow box with 2.25" pipes up the manifold , not too noisy but sounds nice
nick
leeparkes
Post Fri Nov 27, 2009 11:57 pm
Im running twin 50mm pipes (scorpion M3) as this is what an M30 is suposed to run best with but when i was using twin 46mm pipes (325i system) it seemed to have more low down torque but started to run out of breath at around 5k.
gareth
Post Sat Nov 28, 2009 12:14 am
twin 50mm M3 scorpion parp pipes here too. i've not had it with any other system on but it's the same bore as the original E32 735i system so can't be bad
zaust
Zone day release
Post Sat Nov 28, 2009 9:55 am
Mine goes into a single 3a inch straight through and small back box.
M30 Tech 1 Touring on gas.
volgapower
Post Mon Mar 15, 2010 1:01 am
i can not find any 50mm tubes for sale
only 47mm ones (inside diameter)
will i have problems on high revs?
Kos
Post Mon Mar 15, 2010 1:11 am
zaust wrote:Mine goes into a single 3a inch straight through and small back box.
that probably loses power
www.pukardesigns.com
IG Pukar.Designs
zaust
Zone day release
Post Mon Mar 15, 2010 1:17 pm
If it is then i'm in for a treat when I change Kos :)
DonkeyPunch
Post Mon Mar 22, 2010 10:05 pm
I'm using 3'' with a bullet muffler in the center, and big magnaflow at the rear.
Ugly as hell, but it's been leak tested.
