e30 325i wont run
Artis
Post Fri Aug 26, 2005 3:21 pm
it starts for a second then cuts out help
A1BMW325iSport
Post Fri Aug 26, 2005 3:45 pm
fuel pump, fuel pump relay or wiring
Artis
Post Fri Aug 26, 2005 3:54 pm
on my toura the fuel pump went and it didnt start at all this one starts and cut out after 2 sec
jonmsm
Post Fri Aug 26, 2005 3:58 pm
my mate has the same problem with his quattro, which just had a new GTi tuned engine. The problem can still be the pump, but not its not working at all, but the wiring. His problem is that the fuel pump primes when the ignition is turned on, so there is fuel to start the car, then when he turns it over it bursts into life and dies as the pump doesn't keep running when the end is running.
if you can, hardwire the fuel pump to a battery and when you start the car, connect it up and it should run fine.. if so its probably the relay thats given up. unfortunately not sure where they are in the car for the fuel pump circuit, im sure the Haynes Manual of Lies will tell you though.
Hope this helps mate :)
1986 e28 M535i (gone and missed)
1988 e30 320i cab (full resto STILL in progress)
1996 Volvo 850 T-5 estate (280bhp Turbo Nutter), T-5R (my precious)
1966 Fiat 850 saloon & 1970 Sport Coupe
C1 (go-kart)
Artis
Post Fri Aug 26, 2005 4:05 pm
cheers mate
