how do u open doors that dont work????
eun
Post Thu Aug 25, 2005 9:13 pm
right ive got leather doorcards to get out of a 325
that has been crashed and the central locking
has stopped working!
right hand side of the car opens fine when
you turn the key but the left hand side wont open
from the inside or out
anyone got any ideas as to how i can get the doors open?
someone must know :cry: :cry:
TOURINGDADDY
Post Thu Aug 25, 2005 9:22 pm
if its had a heavy impact it will have twisted the chassis and the doors wont open you'll need to get heavy with it (U BANG IT)
dazleeds
old skool raver
old skool raver
Post Thu Aug 25, 2005 9:24 pm
GRINDER :woohoo: :chainsaw:
www.oldskoolfantasy.co.uk
jonbuoy
TOURINGDADDY wrote:if its had a heavy impact it will have twisted the chassis and the doors wont open you'll need to get heavy with it (U BANG IT)
The door may have been dead locked there for you've got no chance, depends where the impact was?
eun
Post Thu Aug 25, 2005 9:32 pm
well it worked by the key for a couple days after
but then it just stopped!
it had heavy front impact!
but i just cant work out how it worked for a couple
days and then just stopped!
:x :x
is there no other way i can get the doorcards out? :cry:
johnono
Post Thu Aug 25, 2005 9:36 pm
swap the central lockin module over with the one from your car, mabey theres a prob with that?
SwirlyE30
Post Thu Aug 25, 2005 10:03 pm
Grinder, just bodge the fcuk out of it and gride away and get the doors out.Surely if you cut away near the hingers and then the lock and cut away at the door pillar its gota come out.
If not, smash the window, try and prize some rope inbetween the top of the window section and the roof, and drive off with the rope attached to a car lol
1986 Chevrolet Corvette. 330ftlb torque....V8s rule!
dazleeds
old skool raver
old skool raver
Post Thu Aug 25, 2005 10:06 pm
now thats my kinda thinking :thumb:
Dan318-is
Post Thu Aug 25, 2005 10:15 pm
ATTTAACKKK!!
:shoot1: :shoot2: :chainsaw:
TOURINGDADDY
Post Thu Aug 25, 2005 10:16 pm
shout abusive language at the beast :roll:
Dan318-is
Post Thu Aug 25, 2005 10:17 pm
:lol:
touring you any good ways to recondition the whele u sold me?
woking is fooking uselss for leather reconditioners il tell u that! :lol:
TOURINGDADDY
Post Thu Aug 25, 2005 10:19 pm
there is a leather feed but i cant rember what its called, halfrauds sell it
Dan318-is
Post Thu Aug 25, 2005 10:21 pm
leather feed?
nice il have a butchers 2moro cheers fella
n e idea how much?
TOURINGDADDY
Post Thu Aug 25, 2005 10:22 pm
bout 15 big'ns mate
Dan318-is
Post Thu Aug 25, 2005 11:11 pm
your a true daddy
Artis
Post Thu Aug 25, 2005 11:28 pm
get an air chizle and cut the outer skin away then you play around with the door lock without haveing to rip the door panal off
johnono
Post Thu Aug 25, 2005 11:59 pm
eun wrote:well it worked by the key for a couple days after
:x :x
dude , swap the module.. stranger things have happnd :wink:
Artis
Post Fri Aug 26, 2005 12:01 am
air chizle
Bob_S
Post Fri Aug 26, 2005 12:13 pm
brute force or sledgehammer?
p.s I guess you have tired pulling the lock pin up? just checkin!
eun
Post Fri Aug 26, 2005 2:43 pm
um well ne1 know where i can get an
air chisle from?
is that like a mini pneumatic drill or summat?
or i will try the central locking module but not realy sure
how to do this process!
ne1 got any step by step advice?
cheers :(
320Touring
Post Fri Aug 26, 2005 3:00 pm
eun wrote:um well ne1 know where i can get an
air chisle from?
cheers :(
to get the CL module
1.remove grille and speaker down by the pedals in the drivers footwell (1x Xhead screw for the cover and 3x Xhead screws for the speaker.
2. Locate the screws that retain the controller (Brass coloured XHead below hole for speaker)
3. Unscrew these and that should loosen off the holder (located INSIDE the hole for the speaker)
4. remove the holder and unscrew the unit (1x XHead screw)
5. gently remove the plug with the wires (push down GENTLY to release the clip)
6. clip new control module in and try!!
good luck :cool:
Artis
Post Fri Aug 26, 2005 3:02 pm
have you got any mates in the garage trade they with own a air chizle
eun
Post Fri Aug 26, 2005 3:42 pm
thanks for all the help guys much appreciated! :thumb:
Artis
Post Fri Aug 26, 2005 3:48 pm
if you cant get a air chizle use a wood chizle and a big hammer it cuts through panales like butter i know i cut the roof of an e30 that way
