Coming off that pits straight and down paddock hill blind was awesome when confidence was up! Best corner ive come across yet!mattrs wrote:Its a great track, i like paddock hill bend and surtess. Which were your favorite/favorites?
How did your tires and brakes last?
You missed the one where i pass you!Splondike wrote:Twas a good day indeed Matt....here is my beast on track too![]()
The little E30 held its own!
was the m5 on standard suspension ?
It's only an M535i unfortunately and it's far from standard now. It is running larger whiteline ARBs, Bilstein B6 dampers, K-Mac stage 2 adjustable top mounts and a set of Faulkner Springs which are Hartge E28 spec.e30cbe wrote:
the stance looks spot on through the cornersSplondike wrote:It's only an M535i unfortunately and it's far from standard now. It is running larger whiteline ARBs, Bilstein B6 dampers, K-Mac stage 2 adjustable top mounts and a set of Faulkner Springs which are Hartge E28 spec.e30cbe wrote:
Thankse30cbe wrote:
the stance looks spot on through the corners![]()
nice looking car !
we've got to decide between e34 m5 strut legs with brakes, e28 535i legs with uprated billies, custom or aftermarket bars,
so just wanted to know ur set up, thanks
also is the car malachite green ?
