325i sport gearbox ratios
Paynts
Sat Nov 07, 2009 11:17 pm
can anyone tell me what the differnece in the reatios between a standard and a sport box is?
also can you get sport gearboxes second hand or are they like hens teeth?
e301988325i
Sun Nov 08, 2009 10:23 am
325i..........1st 3.83, 2nd 2.20, 3rd 1.40, 4th 1.00, 5th 0.81, 3.64:1 open diff standard
325i sport 1st 3.35, 2nd 2.03, 3rd 1.36, 4th 1.00, 5th 0.81, 3.91:1 lsd standard (tech 2)
That makes interesting reading, I'd like a sport gearbox in mine thank you very much. something else to add to the list.
Does anyone know how to tell a sport gearbox, other than counting input/outputs?
I said:
e30topless said:
lock the wife in there
e301988325i
Sun Nov 08, 2009 3:30 pm
I just made up a spread sheet, figures are based on a 7000rpm redline, 205/55 r15 tyres. I've not taken account of tyre deflection, slip or insufficient power.
325i, with 3.64
1st 3.83 35.4mph
2nd 2.20 61.6mph
3rd 1.40 96.8mph
4th 1.00 135.6mph
5th 0.81 167.4mph
325i sport with, 3.91:1 lsd standard (tech 2)
1st 3.35 37.7mph
2nd 2.03 62.2mph
3rd 1.36 92.8mph
4th 1.00 126.2mph
5th 0.81 155.8mph
sport box with 3.64
1st 3.35 40.5mph
2nd 2.03 66.8mph
3rd 1.36 99.7mph
4th 1.00 135.6mph
5th 0.81 167.4mph
320i g240 gearbox with 3.64
1st 3.72 36.4mph
2nd 2.02 67.1mph
3rd 1.32 102.7mph
4th 1.00 135.6mph
5th 0.81 167.4mph
I said:
StuBeeDoo
Sun Nov 08, 2009 3:37 pm
e301988325i wrote:Does anyone know how to tell a sport gearbox, other than counting input/outputs?
The c/r 'box number (stamped in the bellhousing flange) starts with either "TNN" or "HM"
Interestingly, the 320i 'box has virtually identical ratios to the 325i c/r 'box. The exception is 1st, which is 3.72 in the 320i 'box.
StuBeeDoo
Sun Nov 08, 2009 3:59 pm
e301988325i wrote:325i..........1st 3.83, 2nd 2.20, 3rd 1.40, 4th 1.00, 5th 0.81, 3.64:1 open diff standard
320i.......... 1st 3.72, 2nd 2.02, 3rd 1.32, 4th 1.00, 5th 0.81.
e301988325i
Sun Nov 08, 2009 4:13 pm
Stuart, I've no idea c/r means other than compression ratio but that wouldn't make sense!!!
Lengthening 1st and 2nd by 5mph and 3rd by a little sounds useful to me, as I tend to change up to 2nd and then 3rd very quickly.
Sport gear box, new clutch and bearing, plus a lightened flywheel sounds like a nice improvement to me. My box is rumbly in neutral with the clutch engaged and changing from 1st to 2nd takes ages (worn synchros I'm guessing).
I said:
StuBeeDoo
Sun Nov 08, 2009 5:18 pm
e301988325i wrote:Stuart, I've no idea c/r means other than compression ratio but that wouldn't make sense!!!
Close ratio! :D
e30cbe
Mon Nov 09, 2009 4:55 pm
http://www.unixnerd.demon.co.uk/revs.html
ratios/rpm/speed calculator
bpowell555
Mon Nov 09, 2009 8:40 pm
The 325i Touring has the 3.91 open diff as standard, does it also have the standard gearbox?
1990 325i touring
She's a minter! Best 3 years of my life - bye bye baby :D
StuBeeDoo
Mon Nov 09, 2009 8:57 pm
bpowell555 wrote:The 325i Touring has the 3.91 open diff as standard, does it also have the standard gearbox?
AFAIK, yes. But IIRC you could specify a close ratio 'box in any 325i from new.
bpowell555
Mon Nov 09, 2009 9:47 pm
I'm trying to think how I could work this out but I'm out of brain juice :D
1990 325i touring
e301988325i
Tue Nov 10, 2009 5:11 pm
What do you want to work out?? I'll do it :D
I said:
Dave_M3
Tue Nov 10, 2009 5:31 pm
A 318iS gearbox is pretty much the same as the Sport close ratio box too... which is probably why a good iS has some sort of a chance against a normal tired 325i.
Tourings with close ratio boxes are pretty hard to come by... would have probably been the last thing to be ticked on the options list when somebody pondering buying a silly speced touring 20 years ago which could end up nearly 40 grand when all done.
StuBeeDoo
Tue Nov 10, 2009 8:06 pm
Dave_M3 wrote:A 318iS gearbox is pretty much the same as the Sport close ratio box too...
.... Because it has the same ratios as the 320i.
Paynts
Thu Nov 12, 2009 7:54 pm
ok where do i get one from ?!!! will a 320 box go go straight in? are 325 sport boxeshard to come by?
StuBeeDoo
Thu Nov 12, 2009 7:59 pm
Paynts wrote:ok where do i get one from ?!!! will a 320 box go go straight in? are 325 sport boxeshard to come by?
325i close ratio 'boxes aren't the easiest to find, and when they do appear, they usually command top money. You should find it easier to locate a 320i 'box, but you will also need the front prop to go with it as the 'box is shorter than the 325i one.
HTH
Stuart.
Thu Nov 12, 2009 8:05 pm
HTH
Stuart.
:wave:
http://www.e30zone.net/modules.php?name ... 83#1641883
Dave_M3
Thu Nov 12, 2009 10:18 pm
I got a Sport box for a friend a few weeks ago for around a 150 euro....
Could have got a second one too if I really wanted it :D
wess
Fri Nov 13, 2009 6:03 pm
anyone know how to identify a 2.0 gearbox as am looking for one to put in my 325
e301988325i
Sat Nov 14, 2009 2:54 pm
It's not as strong as the 325 box and the prop-shaft will have to be lengthened as Stubeedoo mentioned above. Overall I don't beleive you'd make a saving, let alone in the long term.
I said:
StuBeeDoo
Sat Nov 14, 2009 3:21 pm
e301988325i wrote:It's not as strong as the 325 box
There are at least 4 people here running 2.7s and 2.8s with the 320i 'box attached and no problems long-term.
**BANNED**
Sat Nov 14, 2009 4:37 pm
I use a 320 'box with my 2.7 with no issues,even still using the lighter 320 clutch!
This is the Getrang 240 'box,same 'box is used in M40/42 but with a different casing to accomodate the differing engine angle.
When BMW developed the 325i,they went right through the car and upgraded any point that was thought to be lacking,bigger front struts,discs at the rear and so on.
The 360 Getrang as fitted to 325 has a bigger case to accomodate bigger bearings,it just confuses the issue that the 'sport' has slightly lower first three gears.
Youth is wasted on the young.
Zaho49
Sat Nov 14, 2009 7:00 pm
I want to know what is the part number of 325i Sport box and standart one?
**BANNED**
Sat Nov 14, 2009 9:32 pm
Gearboxes have a code stamped into front edge of the bellhousing,according to Andy Everitt's 'Restoration Bible' sport 'boxes are HJ/TNN,standard 260 'box is NW,TNW,ANB.
