Instrument Cluster Illumination Burnt
I have a spare cluster, is this just a straight swap, the lights on the speedo are out but everthing else works, the bulbs were replaced but the cluster illumination is burnt out apparently.
Brake Pipes Excessively Corroded
I knew about this, is it a big fix, I know its a pain to do but I better get it done.
Excessive Engine Oil Leaks (Sump & Rocker cover gaskets)
Is this just gasket replacement and if so which ones?
OSF Brake Flexi Hose Mounting Bracket Excessively Corroded
Have had this before and it just needs welded back on
Fuel Tank In Poor Condition
Its cool, I have a spare, explains why I smell petrol
Fuel Filler Pipe Badly Corroded
Which bit is this, I don't have a spare
Number Plate Lamp Units Corroded
One rear lamp is out and I'm guessing can't be replaced because the unit is mullered, can I get a new one?
Wiper Motor Faulty
Have had this before, think I just need a new one, part number would be greatly appreciated
Didn't think there was much wrong with it, flew through its MOT in June but I was warned about the brake pipes. I'd like to gather all of the various parts to cut the cost a little so and advice would be greatly appreciated.
