I'm after a full gasket set for an M42.
Head gasket (the thicker one): 11 12 1 721 550
Timing case cover gaskets: 11 14 1 721 802 and 11 14 1 721 919
Sump to block gasket: 11 13 1 739 592
Sump gasket: 11 13 1 709 815
Profile gasket: 11 14 1 247 837
Timing case to block: 11 14 1 734 422
Timing case upper: 11 14 1 247 849
Valve stem seal: 11 34 9 059 171 (how ever many needed per engine)
M42 gaskets
rix313
Cotswoldbmw
Hi There
Head gasket (the thicker one): 11 12 1 721 550 £53.57
Timing case cover gaskets: 11 14 1 721 802 £8.21
and 11 14 1 721 919 £4.95
Sump to block gasket: 11 13 1 739 592 £11.48
Sump gasket: 11 13 1 709 815 £8.45
Profile gasket: 11 14 1 247 837 £3.32
Timing case to block: 11 14 1 734 422 £7.70
Timing case upper: 11 14 1 247 849 £3.48
Valve stem seal: 11 34 9 059 171 £17.40
Prices inc. VAT delivered to mainland UK
Please call us on 01242 257999 and quote 63521
There is a P&P cost of £1.99 on all orders under £20
Brett
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
rix313
Is the price for the valve stem seal per seal, per pair or the whole engine?
Also, I need a part number and price for the gasket which goes between the main gearbox housing and the rear casing on the Getrag 240 gearbox if possible.
Cotswoldbmw
Hi there
valve seals are per kit for whole engine, can i get chassis number for gearbox
Brett
Brett
Cotswold BMW Parts
01242 335365
01242 335365
