Running 2 amps together.....
I've already got one amp wired up to power the sub but i want to add in another amp to run my component speakers.
I've heard that i can power the 2nd amp from the 1st amp?
Can anyone shed any light on this?
TIA
TIA
kingcruizer
imy. get yourself a two way fues block to power both. one in two out jobby. remote from the other amp will be fine then just run rca's to it. hlh
clive
clive
"BEFORE I DIE, I WANT TO OWN A CAR WITH AN ENGINE THAT STICKS OUT OF THE BONNET"
kingcruizer
whats the crack with the "he who needs...................." bit???? i didnt write that
Can you explain a bit more please
Got a link or pic of what i need?
Oh, it's a forum filter thing mate
Imys will do
Imys will do
fuzzy
its an automated change then? i thought it was people adding that themselves as a joke.
Autochange Fuzzy for some reasonfuzzy wrote:its an automated change then? i thought it was people adding that themselves as a joke.
Asked who/why it was done, but got no reply
kingcruizer
one like this should do. 1 power in 2 power out.ImysE30 wrote:Can you explain a bit more please![]()
Oh, it's a forum filter thing mate![]()
Imys will do
http://cgi.ebay.co.uk/AUTOLEADS-G2-29-F ... 1c0d3bc97d
I need 2 of those then?
Will it not affect the quality?
kingcruizer
just one mate. the power lead from your battery goes in and two power leads come out. one to each amp. quality will be affected if you power off the other amp as your taking power away from the sub amp.
- E30 Zone Meets/Events Team
IMY, that's how mine is set up in the boot, do exactly as Kingcruiser(Btw, where you been
) said and it'll all work.
Any probs, you've got my number.
I get it now
. The remote wire i can just connect it off the 1st amp then?
What about the RCA leads, i'm only connecting the rear speakers to the amp, where would i connect the RCA leads to?
Sorry for the dumb questions
From your h/u assuming you have 2 sets comming out the back of the unit??
kingcruizer
run another set of rca's from your head unit to run the components and yes the remote lead taken from your other amp will be fine.ImysE30 wrote:I get it now. The remote wire i can just connect it off the 1st amp then?
rav.. hows it going mate? ive been working hard in the workshop on my mrs cab. she wants it done and so do i now. then mines going back in for a few touch ups and a few new things
Sanchez
http://cgi.ebay.co.uk/1-RCA-Socket-2-Ph ... 3ef924e309
Buy 2 off theses to split the phono cable for 2 amps.
Will check the headunit, i think there are 2 sets of connections
Thanks for all the info, much appreciated
[quote="kingcruizer][/quote]
[/quote]
Not bad Clive, i take it you're going to put up "Side" exit exhaust so all the puff goes to the pedestrians
Any pics of the missus's cab then???
kingcruizer
if i could have side exits then it would be done. lol
as for the mrs cab.. no pics as yet, its in a sorry state at the mo but i should be putting some primer on it the next few weeks. pic will be up once thats done. ive got her polishing the wheels while im painting the centers. its funny listening to her moan about it but there not my wheels. i could use the buffer and do it in half the time but i want her to respect them once done. it a good learnig curve
What wheels have you got for her then??
Good man, but me thinks there's a hidden agenda behind getting her a cab
Will one of the below wiring kits do:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
The amps only 350W
The amps only 350W
Well if you like cheap and tacky imy, then go for it.I wouldn't waste my money on those.Get some proper kit from an audio shop.ImysE30 wrote:Will one of the below wiring kits do:
The amps only 350W
I'm not too fussed tbh Rav, the 2nd amp will only be powering the rear speakers, i've got proper stuff fitted for powering the main thing, the massive sub
then go for the first one in the link.
That's the one i've bought
Should be hopefully all set-up for the Midlands Meet
use the biggest power lead you can and split it to power both amps
The one i've already got fitted is very good, best one that Vibe do
I've had complaints from my neighbours a few times
