compression tester
e30bmlover
Ac Schnitzer prophet
Post Sun Oct 11, 2009 2:04 pm
right! im going to buy a compression tester for when i find my new engine!!
just one problem... what are the cylinders supposed to read on a m52b28?? is it as close to 200psi as possible??
Post Sun Oct 11, 2009 2:25 pm
e30bmlover wrote:right! im going to buy a compression tester for when i find my new engine!!
That they are all similar is of more relevance than the actual PSI measured, unless they are all 0 ! :eek:
What are the readings on your pots Bumlover ?
e30bmlover
Post Sun Oct 11, 2009 3:59 pm
alright pete?
here we go...
1 = 177
2 = 173
3 = 148
4 = 120
5 = 170
6 = 175
compression value in lbf/in2
skipunda
Post Sun Oct 11, 2009 4:04 pm
you want to give it several goes and average it so ive heard
Chris
e30bmlover
Post Sun Oct 11, 2009 4:07 pm
skipunda wrote:you want to give it several goes and average it so ive heard
lol.. they did..
Andyboy
Alpina Colada
Post Mon Oct 12, 2009 12:24 am
e30bmlover wrote:alright pete?
here we go...
1 = 177
2 = 173
3 = 148
4 = 120
5 = 170
6 = 175
That's shagged. 177 is sort of okayish, 148 is Not Good and 120 is bolloxed.
e30bmlover
Post Mon Oct 12, 2009 1:11 am
what should the values be Andy?? the numbers i gave were from the compression test i had done 17 days after getting the car.. so i can only guess its worse now lol.
Post Mon Oct 12, 2009 7:55 am
Ideally they should all be up around the 175 to 200 mark but engines vary greatly.
But as both Pete and Andy have said. If they were all at 170, I wouldn't be too worried but to have a difference of 57psi between readings tells me it's f*cked.
e30bmlover
Post Mon Oct 12, 2009 11:39 am
B7 wrote:Ideally they should all be up around the 175 to 200 mark but engines vary greatly.
oh... lol... well i could have told you that by the way it drives lol.. lack of power ect ect..
