Taking out parcel shelf?
- golf_killa
I need help on taking out the parcel shelf as i want to fit speakers, but i cant find any way of getting it out, anyone got any ideas?
Simon
- Contact:
Remove the rear seat bench and backrest, ( bench lifts out, seat back needs 2 small bolts undoing in the lower corners then that will lift and pull out too) undo the seat belts at their lower mounting points, then you should be able to grip on the parcel shelf and lift it (it will be secured by 1 small plastic clip) then it shoud pull free feeding the seat belts through the holes in the parcel shelf.
- golf_killa
