Can't be a lot wrong with the engine block to battery neg. path if it cranks OK, without smoke and sparks, and the earthing point for the engine loom is actually between the battery neg. lead and the lead's connection to the body.willnz wrote:Brian, just thinking of the unexplained problem Murran had with his m20b25 equipped e21. Maybe some sort of grounding fault? Malcolm seems to have swapped out everything possible...??
Could remove the loom earth lead from the stud on the suspension turret plate, clean it up and refit, but it's not a place known to give trouble.
