AndyBird
Post
Sun Aug 21, 2005 4:58 pm
got it all together its all in connected up coolant in oils in quick shifter in all ready to go
now how the fcuk can i sort the wiring!!!!!!!!
i need to connect the jetronic plug which is a rectangle to the motronic fuse box which is a circular plug im thinking im gonna have to rewire the car
as i cant sort it at the moment if thats the case how the fcuk do you get the dash out?
cheers all
Martinaston
Post
Sun Aug 21, 2005 5:05 pm
You have to go through both loom's wire by wire.
It will take forever and the haynes manuel has the wrong colour codes so double check the lot before even thinking of putting the battery back on.
Where are you?
There is NO nucleus.
Widge
Post
Sun Aug 21, 2005 5:23 pm
Does any one have a list of what pin no's in the motronic plug (and or the jetronic plug) do what? As I'm sure it'll really help
Martinaston
Post
Sun Aug 21, 2005 5:47 pm
I've got an adapter already made (somewhere
Widge
Post
Sun Aug 21, 2005 5:48 pm
I'm sure Andy Bird will be very pleased to hear that!!!!!!!!!
See if you can dig it out mate and keep another E30 going
Ant
- Retired Team Member
Post
Sun Aug 21, 2005 6:37 pm
Use a motronic loom from a 320/325 of similar age to the car dude !
you'll need the sensors etc and AFM but its worth it , the effort required is same for both, using the motronic is the best option IMHO.
I have pinouts if required, mail ant-AT-e30zone.co.uk for those and I'll get them shot out ASAP
Email FTW
AndyBird
Post
Sun Aug 21, 2005 8:27 pm
cheers for the help guys tops
i presume if i swap the wires from the jetronic plug to the ones on the motronic plug that is the way forward? ie cut the jetronic plug off the 323 and wire it to the motronic one on the 318.
i take it then i would just swap the rev counter thingy on the back of the rev counter due to it being a 6 cylinder now where is the rev counter and speedo taken from? is it part of the plug?
AndyBird
Post
Sun Aug 21, 2005 8:28 pm
Martinaston wrote:You have to go through both loom's wire by wire.
Where are you?
im in northants btw
AndyBird
Post
Sun Aug 21, 2005 8:34 pm
oh and hasnt one of the plugs got more wires than the other?
AndyBird
Post
Sun Aug 21, 2005 10:11 pm
cheers m8 will look to see if it helps
Jos
Post
Sun Aug 21, 2005 10:12 pm
the ETM is still uploading lol, didn't expect you to reply that fast!
Will give you a shout when its done, about 30mins or so...
'94 e36 tree climber
Martinaston
Post
Sun Aug 21, 2005 10:32 pm
I think the clocks are incompatable
By the time you go through all the diagrams it's just as quick to change it to motronic
(distributor)
Jos
Post
Sun Aug 21, 2005 10:37 pm
ok its done now, good luck.
AndyBird
Post
Mon Aug 22, 2005 9:12 am
Martinaston wrote:I think the clocks are incompatable
(distributor)
how do i go about changing it to a motronic? how many sensors is there to change? and how much would i be looking at? surely i would need a 325 ecu and engine wiring loom would that then plug into the motronic plug next to the glove compartment?
surely its easier to splice the plug from the 318 engine to the 323 plug and plug the 323 plug into the engine and the 318 plug into the motronic plug? would this not work? then just need to figure out the RPM thing as its going from a 4 to 6 cylinder?
AndyBird
Post
Mon Aug 22, 2005 10:01 pm
need more help guys if i get a 325 motronic loom what else do i need? a 325 motronic ecu? which sensors do i need and do i need to change dizzy etc? surely this will be mega expensive?
as i have got the 323 on the drive still i reckon i may just rewire the whole car swapping clocks etc as it is my drift car and not a daily driver
Jos
Post
Mon Aug 22, 2005 10:56 pm
Do you have the 323 ECU? Presumably you do..
On the round connector (motronic I assume)
Pin 14, BK/WH comes from motronic unit "Speed Signal Input". Is BU/YL in fuse box and goes to the Speed Input of the Instrument Cluster.
I think this is the rpm gauge line, the Speedo should be ok as it comes from the diff does it not? So you need to find where it goes to from the cluster and splice pin 14 from the engine loom onto it? <insert disclaimer> Pretty sure most of the info is in that txt doc m8.
As you said, you could just lift the entire loom from the other car..
Martinaston
Post
Mon Aug 22, 2005 11:02 pm
All the facelift cars have a coding plug that goes into the instrument cluster so you need the corresponding one that goes with the engine but the 323 was never run with motronic so there's no plug for it.
Making an adapter plug would be the most convenient but as to how it would run i have no idea
If you change the fusebox thats the whole car and that means the lights as well or you cut and splice to keep the facelift connectors
rather you than me.
AndyBird
Post
Tue Aug 23, 2005 8:58 am
sod it as its not a daily drive im gonna swap the loom as ive got the whole dash from the other one too it shouldnt be too hard as the entire interior is stripped anyway in both cars no carpets or anything and i wont be putting the dash back in!!!
