auto to manual
TOURINGDADDY
Post Sat Aug 20, 2005 10:10 pm
as above we got a dead 320 manual, we need to change this as soon as and we got a 325 bottom end and gear box manual and a complete lump attached to an auto what needs to b swapped to make this lump a manual.
Artis
Post Sat Aug 20, 2005 10:59 pm
all you need to change is the fly wheel and stick a cluch on it theres your manaul engine
mrLEE30
Post Sun Aug 21, 2005 7:40 am
and spigot bearing and prop shaft and (optional)engine wiring loom, and centre consol, and clutch master/slave cylinder.
about to do it myself, if you have a dead donor car shold only need to buy a spigot bearing from dealers.
mrlee
Brian28
Post Sun Aug 21, 2005 10:02 am
Did mine yesterday. If the car your converting is an auto take pedal box and clutch cylinder from the donor. Just read the original post, ignore that bit of useless info. A new spigot bearing, press fit into the end of the crank, manual flywheel and clutch/pressure plate, I'm not sure if the lower removable bit of the bell housing (engine side) is the same, you need to take it off anyhow to get at the torque convertor bolts so swap if its different to the manual one.
For sale - E30 320i racer project - sold.
