ABS brake question
bobbin1982
Post Thu Oct 01, 2009 12:00 am
Ok here goes ill try and explain best i can
I changed my front brake pads not too long ago and ever since i have been having this weird problem
When im stopping the car normally for traffic lights for instance i get nearly stopped and the brakes get stiff and not do anything then suddenly loosen up and work properly
And also when i put the car into reverse after stopping i try to brake after reversing and the brakes grip and wont release easy then release themselves?!?!?!
Its not dangerous but very annoying :x
My discs have a few scratches in as i didnt change the pads in time.. will this have anything to do with this?....
Oh by the way i can feel its the fronts and not the rear and it also makes a creaking noise sometimes (not squeeking)
Cheers. Andy
Driving my digger!!!!
bobbin1982
Post Thu Oct 01, 2009 5:27 pm
Ah thaty sounds like a possibility as when i was changing the brake pads i accidently dropped the caliper a couple of times so it put stress on the pipe...
Ill also change the fluid at some point soon..
Whats a proportioning valve and what does it look like? lol
Cheers, Andy
**BANNED**
Post Thu Oct 01, 2009 5:43 pm
Cheers, Andy
This valve is mounted on the engine bay side of the l/h inner wing,in the brake line(steel pipe)that runs from the brake master cylinder to the rear brakes.It's about 2'' long and a bit under an 1'' round.Difficult to see from the top with the engine in!
Youth is wasted on the young.
