Power Washers
Eddie25
Post Sun Sep 13, 2009 12:20 pm
Any advice much appreciated ladies and gents.
I am off out with the intention of buying a power washer for the E30 today but it seems a mine field of options. The only criteria I have laid down so far is it must cost around £250 max and must have a soap dispenser for snow foam etc. Just wondered if you could recomend anything:
1) What pressure range do i need to consider? I want enough pressure to get wheel arches etc clean but don't want to blast the paint off.
2) If it does have a soap dispensor can you add normal autowash? Zymol is a favourite but i dont know if the concentration would be too high? I've heard good things about snow foam however.
3) Having used Karchers at work for years i know they are extremly good but would another/cheaper brand be suitable for my uses?
Regards
Eddie
tez180
Post Mon Sep 14, 2009 9:20 pm
This - http://direct.tesco.com/q/R.206-8142.aspx
Brilliant for the money. And reliable.
And this - http://www.cleanyourcar.co.uk/washing-a ... d_371.html
Best on the market, great with Megs hyperwash mixed 1:10, or your fav product. I also use it with Megs All purpose cleaner strong mix for arches and lower parts of the car.
Hope that helps.
mattsbmw
Post Sat Sep 26, 2009 11:55 pm
I use a Nilfisk power washer from Screwfix the c120 less than £100 and i find it fantastic.
320Touring
Post Sun Sep 27, 2009 12:01 am
mattsbmw wrote:I use a Nilfisk power washer from Screwfix the c120 less than £100 and i find it fantastic.
Paul has one of them at the unit- Excellent-and stands up to commercial use-I'd recommend it in a heartbeat!
