m50 engine swap problems
dugie
Fri Sep 25, 2009 8:26 pm
I have just put my m50 engine in my e30 and the exaust manifold is resting on the stearing rack does any one know if i need to cut and shut the old manifold or if i need different ones? also any tips on secureing the loom to the fire wall?
blue30
Fri Sep 25, 2009 8:35 pm
You have to hack the manifold to bits, or pay nearly a grand for a pre-made one. Or get lucky like me and buy a pre-hacked M3 manifold from someone breaking a coversion :D
Not sure myself on the loom - tomorrow I'm going to try cutting it out of the black plastic box, bundling it up with tape & ties and using the old cable tray to hold it in place, and see how that looks.
Fri Sep 25, 2009 8:41 pm
4 pot wiring cover for the loom
Fri Sep 25, 2009 9:18 pm
Search out some M50 swap threads and you wont need to ask these questions, the best bit is you will also find out another load of useful info!
dugie
Fri Sep 25, 2009 10:08 pm
Jhonno wrote:4 pot wiring cover for the loom
My car was a 316 so will the loom holder from that work then?
Fri Sep 25, 2009 10:37 pm
Yup
Fri Sep 25, 2009 10:41 pm
316 no
316i yes
dugie
Sat Sep 26, 2009 11:43 am
DanThe wrote:316 no
316i yes
It was a g reg 316 auto i'm sure its an injection.
Also is yours lump strockered from 2.5 to a 2.8 if so how did you run your motor in i've been hearing mixed info wanted to ask someone who's done it?
gcs325i
Sat Sep 26, 2009 1:30 pm
Is the manifold your using cast iron or tubular m52 manifolds? cast can't be modified easily/at all, tubular ones can be cut and welded with relative ease.
dugie
Sat Sep 26, 2009 6:41 pm
gcs325i wrote:Is the manifold your using cast iron or tubular m52 manifolds? cast can't be modified easily/at all, tubular ones can be cut and welded with relative ease.
Its a tubular m52 one do you know exactly what i need to do bearing mind i can't weld? because i've started wondering if it would be easier to just get a bloke from power flow in to make one up but that could be quite expensive
