http://www.realoem.com/bmw/showparts.do ... g=32&fg=20
Parts: 6,8,9,10,13
Not sure of the availability.
the problem is there seems to be a small leak at that connection, hope these parts will fix that.
Price with postage to W2 London area please.
Steering parts please
- Cotswoldbmw
- Contact:
Hi there
as you can see from real oem differant numbers depending on age, can i please have chassis number
Brett
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
Hi,
Thanks will forward the info via PM this evening if thats ok and also want to add the sump gasket to the order and also is there anything else you would recommend changing while changing the sump gasket?
Shaz
Shaz
- Cotswoldbmw
- Contact:
Morning
No 6 £29.29
Says for yours you dont have 8,9,10 do you def have that fitting on the end
No 13 £1.15 each
Sump Gasket £8.74
F-Anti roll bar links,brackets and nuts x2 of each £64.89
R-Anto roll bar links,brackets and nuts x2 of each £27.31 inc
Ref No 49232
All prices inc vat,discount and delivery to minland uk
Regards Karl
No 6 £29.29
No 13 £1.15 each
Sump Gasket £8.74
Ref No 49232
Regards Karl
Cotswold BMW Parts
01242 335365
01242 335365
Sorry for the long delay, car was off road due to other engagements.
but i still require the above parts except the anti roll bar parts,
No 6 £29.29
"Says for yours you dont have 8,9,10 do you def have that fitting on the end" (YES, INCLUDING THESE PLEASE)
No 13 £1.15 each
Sump Gasket £8.74
can i also add an ICV? and
full service kit ie; spark plugs filters etc...
sorry not sure what its called so will attempt to describe it, the drive shaft seals for the diff its the shafts that connect to each side of the diff ie; if your looking at the vehicle from the rear the left and right side of the diff as there seems to be a slight leak from the right side
also the seal where the prop connects to the gear box as there also seems to be a small leak, please contact me if you need the above requests clarified
Can you please give me total price posted to london W2
I can send the chassis number again if needed
No 6 £29.29
No 13 £1.15 each
Sump Gasket £8.74
- Cotswoldbmw
- Contact:
Hi There
sorry for the delay can i get chassis number again
Brett
Brett
Cotswold BMW Parts
01242 335365
01242 335365
