but here goes -
equipment used:
*black and decker mouse (as a zoner recommended)
*Sandpaper grades - 80!!, 240, 400, 600, 800, 1000, 1200, 2000, and 2500 (basically paper!)
*nitromors (a little bit)
*random orbital sander with lambswool bonnet
*autoglym metal polish
*meguiars alloy polish
before:
i tried to nitromors the wheels to save the money on getting them stripped, however in doing this i discovered the lips had been diamond cut previously - the paint on these bits came off really easy with nitromors (almost too easy) . but the centres however had 5000 coats of paint on them!! and even nitromors didn't touch them!!
So it was off to a company in teeside called Romax. they charged £68 to acid dip all 4 with tyre and valve removal and they got rid of the big kerbed bits and a flat spot! (basically a refurb without repainting) great guys and great price. imo.
the finish of the alloy itself was still quite pitted even though they never saw a shot blasting! maybe they had before in a previous life ??
didn't take too many pictures while i was polishing . mainly cos i looked like i had been in a coal mine!!
but it involved painstakingly working my way through the grades of sandpaper (grades as above) until smooth (as mentioned before the pitting was as bad as having to use 80 grit in places). to save time the grades i didn't have that fit on the mouse - which was nearly all of them! i made myself by tracing around the sandpaper to the mouse's base shape then double sided taping them onto another old piece that is designed to go on the mouse (the velcro stuff on the bottom). amazingly this worked well!
the mirror finish was the real ball ache. mainly due to trying so many different techniques to acheive it, first i tried a sisal mop on my drill with blue and brown compounds- this is v v v hard and i ended up with marks/lines everywhere and when i slipped with the drill and dingged it i had to get the sandpaper out and start again
then i tryed axle stands on the back of the car and spinning it in 5th gear (as per youtube vids i had seen) this worked well but figured i could only do the lips , so did one and stopped as i prefer my fingers where they are and not in my rear arch!!
plus i had no fuel left!!
final finish was acheived with a random orbital sander and a mix of autoglym and meguiars polishes. meguiars i found was better.
the pictures don't really do them justice as the lighting in my garage is crap.
the valve in the last picture is not going on the originals are going back on (didn't realise they were stamped up as RH until i nearly chucked them!) the new ones look crap!
the bits in between the spokes are to be painted black (minus the small raised text - one of which says e30!!) and the text carved into the wheel will be black inside too.
undecided on the centre caps at the moment and have a few sets to choose from - none of which are the RH ones as theres one missing!!
got transformers and BMW to choose from - your thoughts welcome.
what do you think??
and yes i know most people hate RH toplines - i don't need to hear it. lol
questions welcome.
