Right, My M50 engine is finally ready to go in but i would still like to get rid of the oxidisation on the engine, does anyone know of a good product to bring it back to new?
I've tried petrol, gunk etc but it doesnÔš't really touch it.
Engine cleaning
Well, I've used one of those wee round wire brush things that go into a drill to clean the major crap off the side of a Standard Vangard engine, and it worked OK. Again, not wonderful, but it did a reasonable job. I just sprayed the engine with red primer to keep the rust down a bit.
Once driven, forever smitten.
Direct injection, turboed, intercooled, 16 valves giving a whopping 48.5hp/litre!!
mix up 80%parafin with 20%washing up liquid and wire brush it on then wash off cleans very well
makes the same stuff you buy for degreasing etc in motor factors think they call it gunk but my method works really well hth Daz
www.oldskoolfantasy.co.uk
Martinaston
B&Q do a black spray paint for wood stoves for about Ԛ£7 so it should handle the heat OK.
I bought some but haven't got around to using it yet, I think it's a matt finnish that can be applied to rust the same as hammerite.
Just out of interest does anyone know what hammerite is like with high temeratures?
There is NO nucleus.
I used some VHT black spray on my cam cover, not fitted it yet on account of being too lazy to go and buy a new cam cover gasket. It usually gives a matt finish but is designed to be applied to exhaust manifolds and stuff so being applied to the block shouldn't really challenge it much. You can get clear laquers for engines too.
vht spray mmm
sounds good gonna have to do all mine again as i scratched it badly fitting
good tip
may just do exhaust too
