does anyone have any experience of this and how to avoid it before it happens???
thanks
profile gasket failure on m42's
Ant
- Retired Team Member
common problem dude, the replacement parts are modded and less prone to premature failure
Email FTW
Easy fix, sell it and buy a car with a proper engine
jello
Some of the bits i got to repair mine...
Qty Code Description
1 11.12.1.721.546 Head gasket
SET 11.12.1.721.939 Head bolt
SET 11.12.1.721.734 Flat washer (head bolt)
1 13.62.1.709.966 Temperature sender (blue)
1 07.11.9.963.130 Gasket ring (temp sender)
1 11.14.1.247.849 Profile gasket (rear)
1 11.14.1.247.837 Profile gasket (front)
1 11.14.1.721.919 Gasket set (upper timing cover)
1 11.14.1.721.802 Gasket set (lower timing cover)
1 11.14.1.439.570 Crankshaft seal
1 11.51.1.727.468 Water pump
1 11.51.1.714.519 O-Ring (water pump)
1 11.53.1.721.172 Gasket (thermostat housing)
1 11.53.1.721.218 O-Ring (thermostat)
2 11.62.1.728.983 Exhaust manifold gasket
1 11.61.1.734.684 Inlet manifold gasket (lower part)
1 11.61.1.717.761 Inlet manifold gasket (upper part)
1 16.12.1.180.409 Fuel pipe
2 13.54.1.743.261 Gasket (throttle body)
1 11.15.17.27.509 Vent Hose
1 11.42.1.727.300 Oil filter & o-rings
1 32.42.17.17.953 Power steering fan belt
Saves money if you do it yourself, but there is always the possibility of buggering it up completely...
Demlotcrew
Pete you know that you love them really! (four pots that is)pacerpete wrote:Easy fix, sell it and buy a car with a proper engine.
A
kevin316i
There was an issue with the coolant eating into the material of the original profile gaskets on the M42 engines.
