First drive+ pix added
ian332isport
Fri Aug 19, 2005 7:50 am
Ant,
You may want to re-route the O2 sensor wiring. Having a millivolt signal cable tied to the HT leads is probably not ideal :lol:
Ian.
Ant
Retired Team Member
Retired Team Member
Fri Aug 19, 2005 8:04 am
Its not actually tied to the HTs Mate, sure is close though :lol:
Will revise the routing for that today dude, cheers for that
buster
Fri Aug 19, 2005 4:24 pm
:rofl:
Dry ,very dry :teehee:
Ant
Retired Team Member
Retired Team Member
Mon Aug 22, 2005 7:23 pm
:eek:
Slipery when wet folks !
had a few brown moments today, must admit I have turned the boost down until it hopefully dries out.
Fuel consumption wise................ yep, she likes the go juice Ԛ£36 to 106 miles , not soo bad as I have been tweaking the car whilst stationary most of the weekend attempting to improve the idle quality- I ahve failed so far :lol:
Len, will look out those 02 for ya tomoz m8. Too much to do today.
Andy335Touring
Mon Aug 22, 2005 8:17 pm
Ouch, I thought mine was bad ! :mad: :D
It's all good fun though :)
Apart from the idle have you about finished the part/full throttle maps ?
johnono
Mon Aug 22, 2005 8:42 pm
well done ant :D ,.. glad it all came together nicely, and lookin forward to the video clips :cool: :cool:
lentec
Boost Junkie
Tue Aug 23, 2005 12:47 pm
Nice one ant let me know.
I think ive got problems will post an update when i know for defenate!! :(
astondg
Wed Aug 24, 2005 12:39 am
Well done! I'm looking forward to some hp and maybe acceleration figures. Should be quick.
ant wrote:Fuel consumption wise................ yep, she likes the go juice Ԛ£36 to 106 miles , not soo bad as I have been tweaking the car whilst stationary most of the weekend attempting to improve the idle quality
That's only a tiny bit worse than my non turbo 323i. Depends how much you paid for the petrol per litre but it is about 23L/100km and mine gets about 22L/100km.
Aston
BMW E30 323i with some stuff
1:05.17 @ Queensland Raceway Sprint track
1:10.09 @ Queensland Raceway Clubman track
1:21.67 @ Morgan Park Raceway
Ant
Retired Team Member
Retired Team Member
Wed Oct 12, 2005 11:13 am
Bit bored today so a mini update on this.
Long term the car has been 100% reliable, had to tighten the manifold nuts a few times but thats a familiar issue with the M20
Fuel consumption is no better :lol: in traffic the car is fine, docile as stock with just a hint of a "bobble" if you idle for 10+ minutes, its a heat soak issue I think , damn that intake manifold gets kin hot too !
Boost is still set very low, had a lot of issues with laptops so tuning has been on hold until now, finally managed to get the laptop to run( POS P1MMX thing) by basically porting the entire contents of my desktop onto CDR and playing with the settings, who said XP and win98 are compatable ??? I'd like to stuff their head into a jar
Today is a real event, the Innovate Wideband 02 is finally fitted and setup !!! gonna take a few short drives to see whats what and now I get realtime AFR displayed I can tweak til I'm out of fuel or skill, whichever comes first.
I've decided that assuming I'm rich under boost( should be mega rich) I will up the min boost from its current 5.5 to 8 ish and tune for that, no sense tuning for its current level as its simply not enough winkeye
Update later on this, hopefully good news :lol:
Toby_Unna
Boost Junkie
Wed Oct 12, 2005 12:37 pm
sounding good Ant :cool:
well i'm just off to the breaker to prise a turbo from a volvo, not quite in the same league as you but i am trying!
e30_Turbo
Boost Junkie
Wed Oct 12, 2005 12:51 pm
YES!! IT WORKS!!!
Ow am I happy I bought that WB, bring on the easy tuning and more BOOST!!! :D
Jon_Bmw
Dangerous when thinking
Wed Oct 12, 2005 12:57 pm
Sweet news Ant and Mark(as i know its your wideband Mark) Sounds like you'll be dumping even more once you have more boost, more boost=more gearchanges=woooosh chirp.
Good news toby as well, make sure you get the model of the volvo and maybe even the chassis number then you can get the right turbo to manifold gasket off the dealer(not that that'll be the first thing you want to worry about)
MOT in a week and a half :?
Turbo-Brown
Boost Junkie
Wed Oct 12, 2005 2:09 pm
Sounds like good news alround Ant!
Have you got one of those G-Tech things that can give an indication on power?
Be interested to see what people are getting.
I know I've asked this before, but can't remember where the answer is :oops: What plugs are you running? Gotta sort these out at the weekend :)
Cheers!
e30_Turbo
Boost Junkie
Wed Oct 12, 2005 3:34 pm
Turbo-Brown wrote:Sounds like good news alround Ant!
So far, based on 2640lbs (1200kgs) I'm getting 225bhp at the rear wheels.
Cheers!
BR7PES plugs, or something like that....I'll try find out later for def :D
e30_Turbo
Boost Junkie
Wed Oct 12, 2005 3:44 pm
Q: What plugs should i use? what should i gap them to?
A: NGK 3923 BPR8ES plugs. Their 3 degrees colder than stock. i gap them to .025"
Toby_Unna
Boost Junkie
Wed Oct 12, 2005 5:24 pm
got a turbo guys 8)
not a permanent solution, the tub might be ok, there's a bit of lateral shaft play though, but will be great for mocking up and i'll be able to use the manifold flange i think. also got a big big downpipe with a couple of nice bends in it which should be a lot of use to cut up, all oil/water pipes and unions, and a load of charge pipes and also a separate bypass valve thing between comp inlet and outlet, what that is i don't know. not IDd the tub yet but it's a Garret T3 i guess, quite big. Ԛ£20 the lot, not too bad.
lentec
Boost Junkie
Wed Oct 12, 2005 5:25 pm
Good news :D
Glad im not the only one thinking MORE BOOST! :twisted:
its a bit easyer for you turbo guys tho! i got to turn a bigger pulley up.
Been mapping on a daly basis and found those 42lb'ers are sucking
my fuel rail dry :eek:
alex im running NGK BP6E bit colder than stock but the place that
begins with an H! had an offer 3 for 2 on plugs so two full sets for a six
Jon_Bmw
Thu Oct 13, 2005 9:06 pm
Sweet Toby, your scrappy sounds super generous, all that stuff for Ԛ£20, you could flog it on ebay for much more.
No going back now, it does look like a t3 flange to me, but I find it difficult to tell the difference between t3 and t25(used on rover's someone reliable informed me on here)
I bet you are buzzing in anticipation, i'll keep my eyes and ears out for anything else that might be of interest to you(FMU, big injectors, etc)
Gotta go misses is on my back for spending to much time on here and not enough with her.
Once again :cool:
Toby_Unna
Boost Junkie
Thu Oct 13, 2005 10:40 pm
Once again :cool:
that sounds familiar :(
it's a TB03, thanks to Ant for staying up half the night trawling through volvo forums, yuk!
lucky because similar later cars used a smaller turbo. and also what thought was too much lsteral play on the shaft turns out might be fine and within tolerance
pretty happy!
