Diff ratio question
stulane
Post Thu Aug 18, 2005 11:56 pm
Hi,
I have a e36 325i diff ('92) and i was wondering how to work out the ratio?
Thanks,
Stuart
jay528ise1985
Post Fri Aug 19, 2005 12:41 am
Think you'll find it's a 3.15:1
1989 BMW 320i 2.7 2 door saloon
stulane
Post Fri Aug 19, 2005 12:44 am
I've taken the insides of the e36 diff and put it into a e30 casing. I'm going to be running a 2.5 M50...
Do you recon thats worth keeping or should i try and get something with a higher ratio?
M3Compact
Post Fri Aug 19, 2005 8:33 am
stulane wrote:I've taken the insides of the e36 diff and put it into a e30 casing. I'm going to be running a 2.5 M50...
If you've stripped it and it's a 3.15, it should have 13 teeth on the pinion and 41 on the crownwheel.
jay528ise1985
Post Fri Aug 19, 2005 9:36 am
Depends whether you want to sacrifice relaxed motorway cruising for acceleration or vice versa!!!!!
stulane
Post Fri Aug 19, 2005 10:15 am
Id rather have good acceleration and lower top end. most of my driving is town driving atm.
jay528ise1985
Post Fri Aug 19, 2005 4:25 pm
In that case you'll be better off with a 3.9:1 or as a compromise a 3.73:1, both standard E30 fare.
320Touring
Post Fri Aug 19, 2005 4:30 pm
are you using the m50 engine and gearbox??
if so, iirc the final drive in 5th is 1:1 in the e36 box as opposed to the 1:1 ratio being 4th in an e30 box
ergo you need a much lower final drive ratio to give you comfortable cruising
stulane
Post Fri Aug 19, 2005 4:31 pm
Cheers, I'll give this a try and see how i get on.
I guess i'd like better fuel economy anyway.
stulane
Post Fri Aug 19, 2005 4:33 pm
I'm using 325 M50 engine with its gearbox with a e36 325 diff.
320Touring
Post Fri Aug 19, 2005 4:35 pm
well they should be matched ok -3.15 :1 will be fine :D
