The Most Infamously Common E30 Fault
Fri Sep 18, 2009 1:01 am
beemerbird wrote:
skipunda wrote:ABS light stuck on due to a relay
Good call.
Thats a prefacelift thing i'm sure.
SPADGE
Fri Sep 18, 2009 1:30 am
bss325i wrote:
Good call.
Early facelift and all pre-facelift cars with the ABS relay above the glove box suffered with this problem mainly after jump starting which would fry the relay.
Fri Sep 18, 2009 1:35 am
Can confirm.. Jai's early facelift had the jammed relay
Fri Sep 18, 2009 1:37 am
Our cabby had lots of the common problems.
Wet footwells
Central locking not working
Manifold bolt shearing
Nakerd instrument cluster
Hood ripped
poolnoodle
Fri Sep 18, 2009 2:34 am
Around these parts it's without a doubt the cracked dash, closely followed by dodgey temp gauge, speedo, odometer, etc
DRIFTBOY
Fri Sep 18, 2009 2:47 am
Broken rockers (depending on engine)
Camshaft wearing out (depending on engine)
Handbrake backplates - shoe pins pulling through the rust
Brake light switch keeping brake lights on
Not really a fault but 14 turns lock to lock on the standard steering rack bugs me!
basky
Fri Sep 18, 2009 7:42 am
AGE?
DavieP
Fri Sep 18, 2009 7:54 am
basky wrote:AGE?
Sums it all up really winkeye
Dave in Torquay
e30bmlover
Ac Schnitzer prophet
Fri Sep 18, 2009 8:02 am
rear arches
scuttle
intermittent wipers
icv
ropey idle
coolant loss
heater matrix
i would have it all back in an instant!
Brian28
Fri Sep 18, 2009 9:40 am
Most common E30 faults I've seen on the forum are ether about geography or timing, as the good ones are always too far away (why oh why oh why), always come up just after money has been blown on new gadgets, always come up just after buying a different one that wasn't so good, always the wrong time as two months ago would have bought it like a shot or if its still there in three months will definitely have it .... etc etc etc :wink:
For sale - E30 320i racer project - sold.
Morat
Fri Sep 18, 2009 10:17 am
So which zone hero is going to collate this list on the wiki and link to the solutions? :)
Dave_M3
Fri Sep 18, 2009 11:15 am
DRIFTBOY wrote:Broken rockers (depending on engine)
Ahh, it's not as bad as 14... but feels close enough all the same :roll:
For faults, I'd go for
Headlight adjusters not working (Only seen 2 cars with them working and one of them stopped soon afterwards)
Cracked dash,
Broken steering column panels,
Central locking and door lock related problems
Tappy engines (M40s)
Water ingress and Rust :(
Sticking wipers,
Torn seat bolsters
Fri Sep 18, 2009 11:35 am
Had busted seat tilt cables on 2 out of my 4 previous E30's :roll:
zaust
Zone day release
Fri Sep 18, 2009 12:08 pm
The Owner's......
M30 Tech 1 Touring on gas.
Fri Sep 18, 2009 2:14 pm
Only fault i have is Brake wear sensor :P
Jazzy_Jefferson
Fri Sep 18, 2009 2:47 pm
Erm.... I have a lot of the issues already mentioned.
Rather than a thread outlining the problems, how about one that tells you how to solve said problems? Avoiding the need to post anything new on it.
sihooker
Fri Sep 18, 2009 2:56 pm
20 year old cloth seat condition,especially the drivers side!
SeymourCake
Fri Sep 18, 2009 4:45 pm
Jazzy_Jefferson wrote:Erm.... I have a lot of the issues already mentioned.
I co-sign!
Would DEFINITELY be a good idea. I say all the E30 wizards put their head's together and make it happen. It will be time consuming but worth it.
Then it can go on wiki.
E30Gheko
Fri Sep 18, 2009 5:21 pm
Alex wrote:Only fault i have is Brake wear sensor :P
So you have an annoying red light permanently lit on your cluster too?
clipper
Fri Sep 18, 2009 6:17 pm
Another vote for dodgy idle.
Took me 10 times as long to sort out than it took to change head gasket, water pump, belts tensioner, thermostat, coolant, oil and filter..........
Sat Sep 19, 2009 12:07 am
thats the fault, doest annoy me at all since all my e30s have had it on :D
kitch
Sat Sep 19, 2009 1:14 am
mine had rear inner arch rust, speedo not working, electric windows not working properly, brake light warning light, blowing center section, and wripped seats, but sorted all of those faults now :)
6potpower
Sat Sep 19, 2009 1:17 am
Dodgey mileage counters
Barx325i
Sat Sep 19, 2009 8:53 pm
Alex wrote:Central locking
e30's have central locking?
two tone/speed drivers side electric window. every e30 I've owned apart from one, which had winders :D
Sat Sep 19, 2009 9:38 pm
I dont know if your being Sarcastic or acutally dont know :? :D
But yes they do
beemerbird
Sat Sep 19, 2009 9:47 pm
The thing that strikes me about this list is that problems often seem to be pre or post facelift specific in a lot of cases. My idling is spot on, and obviously I don't have problems with headlight adjusters, as I have an early car. It would be quite interesting to compile a list of all suggested faults and see if the pre's or the post's were more prone to them :?:
Barx325i
Sat Sep 19, 2009 9:51 pm
sarcasm rarely translates over the net, in hindsight should have beefed the moment up with a smiley :D
Sat Sep 19, 2009 9:54 pm
the smileys say a lot
:D :) :( :o :eek: 8O :?
fuzzy
He who sleeps with "Gingers"
Sat Sep 19, 2009 9:57 pm
yep, youve got to lay the smileys on thick to get the message across. different forums have different smiley etiquette though with different meanings.
Sat Sep 19, 2009 9:59 pm
fuzzy wrote:yep, youve got to lay the smileys on thick to get the message across. different forums have different smiley etiquette though with different meanings.
I remember you saying on Passion ford everything is followed by a :cry: as they all own fords :P
Barx325i
Sat Sep 19, 2009 10:00 pm
get the wrong smiley and all hell breaks loose 8O :? winkeye
fuzzy
Sat Sep 19, 2009 10:02 pm
no , not for that reason as most seem to own bmw's now. jokes and sarcastic comments are followed by :cry: . i thinks its meant in a shake your head bad joke sort of way.
i got into the habit and a few times on here folk have called me a soft coont for crying so much.
:? :x :-x :o: :cry: :evil: :roll: :?: :shoot2: :chainsaw: :flipbird: :ttiwwp: :bla: :oops: :wtf: :banghead: :fart: :hammer: :soap:
but then its all corrected with a :D
Sat Sep 19, 2009 10:03 pm
:chuckle:
psychochild187
Sat Sep 19, 2009 10:11 pm
Alex wrote::? :x :-x :o: :cry: :evil: :roll: :?: :shoot2: :chainsaw: :flipbird: :ttiwwp: :bla: :oops: :wtf: :banghead: :fart: :hammer: :soap:
lmao
anyway ,. back on topic ..it has to be head light adjusters. has to be number one out of all of them
engine mounts
seat wear
missing tools
temp gauge going nuts
intermitant wipers sticking
dme relay
and jacking points rust
rear axel bushes
