turboing my e30 325i
trav804
hi i got a turbo kit for my e30 its a home made manifold and exhaust to run a t3 the inlet has got uprated injectors but not to sure can i run this on a standerd bottom end??? and i will be running an intercooler? cheers for any help
trav804
and can i run the standerd ecu?
bigbhpwannabe
well the bottom end is fine ,the head gasket will need help though in the form of welded head ,with or with out wire o-rings standard gasket ,or mls gasket used with a stud and nut kit insted of standard bolts , you can use the standard ecu with a chip and riseing rate fuel reg but it is not the way to do itat all ,you need a mega squirt /vems or the like
gary
gary
325i 4door turbo sleeper -
big turb
e36 carbonfibre wietech strutbrace for sale . 07919173179
big turb
charlE30
The standard M20B25 will run upto 10psi on standard internals, anything above that and you want an MLS gasket and ARP head bolts/studs. I've seen setups using the standard ecu with a rising rate fule pressure regulator but it'll never run properly. You'll need some sort of piggy back ecu or a complete standalone like megasquirt.
The above is just stuff I've picked up in other threads and I don't proclaim to be an expert.
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
Gunni
You can run 400hp on standard gasket with ARP studs.
My friend has been running 1.5 bar of boost all summer long like this on a 8.8:1 compression engine.
He does have a welded head.
MLS is only for when you want your 9.7:1 engine to drop into the 8´s.
piltv40
A Megasquirt fitted in an old ECU case and wired in as the original is the easiest
solution to your fuel mapping issue but you will need to add a wide band Lamda sensor to monitor the AFR. a 64 mm down pipe will easy the exhaust plumbing and will not povide too much back pressure.
A small engine bay air ducted intercooler is fine if you don't want to push the boost above what standard engine can reliably cope with 300-350bhp @10 PSI and you don't want to pull the front of your car to bits.
You will need to add a throttle position sensor onto the standard throttle body which is easy.
so, Best of luck
so, Best of luck
Gunni
Boost is totally irrelavent to engines durability/reliability.piltv40 wrote:A Megasquirt fitted in an old ECU case and wired in as the original is the easiest
so, Best of luck
Torque / HP are the only real factors to think about.
And stock M20´s can do over 400hp reliably.
bigbhpwannabe
another thing to consider is that your clutch will die a horible death ,unless you are gonna run barbie power
big turb
big turb
