not up to temperatue then overheats??
k9
Wed Aug 17, 2005 4:47 pm
My 325i touring always seems to run around 1/3 of the way up the temperature dial, whereas my old saloon used to run around 1/2 way, basically in the middle.
My touring seems to run cold unless I hit traffic, then give it 10 minutes and its up to 2/3 of the way and if I don't put the blowers on, it will go up to 3/4?
I've changed the thermostat but no diffence.
Anyone else had this???
K
325icab
Thu Aug 18, 2005 12:46 pm
sounds like your viscous fan is knackered. as it is happining in traffic
Widge
Thu Aug 18, 2005 1:09 pm
I concur on that diagnosis Doctor.
Try getting the car hot then sticking a rolled up magazine in the fan. If it stops the viscous clutch in knackered.
tourer-dan
Thu Aug 18, 2005 1:21 pm
To check the whiskas coupling just stick your fingers in the fan blades with the engine running at full temp. If it cuts your fingers off it's working fine.
sorry I'm having a mad 1/2 hour before I go to work. :bolt:
gcorky
Boost Junkie
Thu Aug 18, 2005 5:21 pm
same as mine just put new coupling on and now you can hear it whoosh........running cool it could sit allday at less than 1/2 way on guage :cool:
